Brother PT-7600VP Labelling Machine
Quicklinx: 704GWS00 Mfr#: PT7600VPZU1
Being able to print your own cable labels on demand makes everyone's job easier, demonstrates a committed approach to safety and enables on-going maintenance to go smoother. And the PT-7600VP allows you to achieve all this and more.
This durable label printer (carry case included) helps you indicate all kinds of components clearly and quickly up to 24mm label widths. And with over 35 common electrical and audio/visual symbols pre-loaded, it makes effective labelling a simple job – you can even tag labels with your own company logo for a professional finish.
Easy to use, efficient and economic, the PT-7600VP has professional labelling all in hand.
  • Versatile barcoding
    Supports a wide range of barcodes including Codabar, Code 128, Code 39, EAN/JAN-13, EAN/JAN-8, Interleaved 2 of 5, UCC/EAN-128, UPC-A, and UPC-E, making it suitable for retail, warehousing, and inventory management.
  • Flexible media handling
    Accommodates various media sizes from Roll (0.6 cm) to Roll (2.4 cm), enabling a wide range of labeling tasks from small to large labels.
  • High-quality printing
    Utilizes thermal transfer printing technology to produce labels with sharp text and images in monochrome, ensuring clear and durable labels for any application.
  • Efficient design
    Features a built-in character keyboard and preview screen, allowing for easy label creation and editing directly on the device.
  • Portable and durable
    Designed to be portable with AA type battery compatibility and a rugged construction, suitable for on-the-go labeling tasks in various environments.
Brother P-Touch PT-7600VP - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
Max Media Size
Roll (2.4 cm)
Min Media Size (Custom)
6 mm x 6 mm
Max Media Size (Custom)
24 mm x 999 mm
Print Speed
Up to 10 mm/sec
Cutter
USB
Barcodes
Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5
Media Type
Laminated tape, non-laminated tape, fabric tape, flexible tape
Compatible Tapes
TZ tape
Fonts
Helsinki
Character Sizes
9 points, 6 points, 36 points, 24 points, 18 points, 12 points, 48 points
Styles & Effects
Bold, italic bold, italic outline, normal, outline, italic
7 line printing
Display Resolution
2 lines x 16 characters
Keyboard
ABCD
Required 6 x AA type Alkaline
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Vista
3-year warranty with product registration
Printer Type
Labelmaker - thermal transfer - monochrome
Printer
Print Speed
Up to 10 mm/sec
Built-in Devices
Preview screen, character keyboard, cutter
Wired
USB
Fonts
Helsinki
Character Sizes
Styles & Effects
7 line printing
Display Resolution
Cutter
Keyboard
ABCD
Repeating Printing
99 copies
Barcodes
Media Handling
Media Type
Compatible Tapes
TZ tape
Max Media Size
Roll (2.4 cm)
6 mm x 6 mm
24 mm x 999 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm)
Max Printing Width
18 mm
1 x USB - 4 pin USB Type B
Carrying case, wrist strap
1 x USB cable
Power adapter - external
AA type - Alkaline
Required Qty
6
System Requirements Details
Windows 2000/XP/Vista - HD 70 MB
Limited warranty - 3 years - carry-in
