With the PT-P700, clear, professional-looking labelling on files, archives, cupboards, shelves, data backup discs and more couldn't be simpler. Just plug direct into your PC or Mac via USB, and create designs using your existing fonts, images, graphics and frames. Features barcode printing and a wide range of downloadable templates available from the cloud, while labels are available in different colours and up to 24mm width.
And with up to 30mm per second print speed, the PT-P700 won't keep you waiting.
- Brother P-Touch PT-P700 - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 710 g
- Max Media Size
- Roll (2.4 cm)
- Print Speed
- Up to 30 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Interface
- USB 2.0
- Barcodes
- Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Postnet, PDF417, Data Matrix, ITF, Micro QR code, GS1 DataBar Composites
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Character Sizes
- 72 points
- Styles & Effects
- Bold, normal, vertical, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround, strikethrough
- 7 line printing
- Battery
- Required 6 x AA type
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x
- 7.8 cm x 15.2 cm x 14.3 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 30 mm/sec
- Interface
- USB 2.0
- 180 dpi
- Character Sizes
- 72 points
- Styles & Effects
- 7 line printing
- Cutter
- Barcodes
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (2.4 cm)
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Max Printing Width
- 18.1 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (2.4 cm)
- Connections
- 1 x USB 2.0 - 4 pin mini-USB Type B
- Media Included
- 1 24 mm x 4 m black on white TZe laminated tape cassette
- AA type
- Required Qty
- 6
- Software Included
- Brother P-touch Editor V5.1
- OS Required
- 7.8 cm
- 15.2 cm
- 14.3 cm
- 710 g
Ink (18)
Brother TZES221 Black on White 9mm | In Stock | £10.87 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.61 |
Brother TZE-651 24MM BLACK ON YELLOW | In Stock | £16.70 |
Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) | In Stock | £11.18 |
Brother TZES651 24mm Black on Yellow | In Stock | £15.76 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.32 |
Brother Tape Black on Yellow 6mm | In Stock | £7.49 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.18 |
Brother Tape Black on Yellow 12mm | In Stock | £11.44 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.42 |
Brother 12mm Black on White Tape | In Stock | £11.44 |
Brother Tape Black on Clear 9mm | In Stock | £7.49 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £9.87 |
Brother TZESE4 Black on White 18MM Security Tape | In Stock | £26.31 |
Brother 12mm Blue on White Tape | In Stock | £9.87 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.80 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.42 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.44 |
Other bundles (1)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.70 |
