Brother TZE621 9MM GLOSS Black on Yellow Tape
Quicklinx: C2PCWS00 Mfr#: TZE621
Type: Tape
£8.39 ex VAT
£10.06 inc VAT
Extensive testing has been performed to ensure that P-touch TZ label is incredibly durable under all kinds of conditions. It holds up extraordinarily well - and stays crisp, legible and affixed - even when subjected to abrasion, extreme temperature, industrial chemicals and sunlight.
  • P-touch TZ label tested to the extreme
  • Abrasion resistant P-touch TZ label
    Brother's patented tape technology ensures that Brother P-touch laminated label can withstand even heavy abrasion.
  • Temperature resistant P-touch TZ label
    Whether you want to use the label in freezing conditions or extremely warm environments, Brother P-touch laminated label has been designed to last.
  • Fade resistant P-touch TZ label
    Wherever you use P-touch laminated label, it will stay as clear and legible as the day it was applied.
  • Water and chemical resistant P-touch TZ label
    Testing TZ label 'to the extreme' has found it to be waterproof and resistant to chemical spill.
Brother TZe-621 - laminated tape - 1 cassette(s) - Roll (0.9 cm x 8 m)
Laminated tape
Media Size
Roll (0.9 cm x 8 m)
Printing Technology
Direct thermal
Media Colour
Black on yellow
Included Qty
1 cassette(s)
Compatible with
Brother PT-D210, D600, H110, H200; P-Touch GL-H100, H105, PT-1000, 1005, 1010, 1080, 1090, 1100, 1280, 1290, 1760, 18, 1830, 2470, 3600, 7100, 900, 9800, D200, D210, D450, D800, E100, E500, E550, PT-GL-200, PT-H100, H101, H105, H107, H110, H200, H500, H75, P300, P750, P900; P-Touch Cube Pro PT-P910
Dimensions (WxDxH) / Weight
2 cm x 9 cm x 7 cm / 30 g
Shipping Width
7 cm
Shipping Depth
1.7 cm
Shipping Height
15.5 cm
Shipping Weight
49 g
Media
Media Type
Laminated tape
Media Sizes
Roll (0.9 cm x 8 m)
Printing Technology
Direct thermal
Media Colour
Black on yellow
Included Qty
1 cassette(s)
Colour Category
Yellow
Compatible with
Brother PT-D210, PT-D600, PT-H110, PT-H200BP , Brother P-Touch GL-H100, GL-H105, GL-H105VP, PT-1000, PT-1000BTS, PT-1005, PT-1005BTS, PT-1005F, PT-1005FB, PT-1010, PT-1010L, PT-1010NB, PT-1010R1, PT-1080, PT-1080BTS, PT-1080SBTS, PT-1090, PT-1090BK, PT-1100, PT-1100SB, PT-1100SBVP, PT-1100ST, PT-1130, PT-1150, PT-1150DX, PT-1160, PT-1170, PT-1170S, PT-1180, PT-1180HK, PT-1190, PT-11Q, PT-1200, PT-1200S, PT-1230PC, PT-1250, PT-1250CC, PT-1250CCVP, PT-1250J, PT-1250LB, PT-1250S, PT-1250VP, PT-1250VPS, PT-1260VP, PT-1280, PT-1280BTS, PT-1280CB, PT-1280DT, PT-1280DT (50TH Year Anniversary Model), PT-1280SR, PT-1280VP, PT-1280VPS, PT-1290, PT-1290DT, PT-1290SBVP, PT-1290VP, PT-1300, PT-1400, PT-1500pc, PT-1600, PT-1650, PT-1700, PT-1750, PT-1760, PT-1800, PT-1800 PLUS, PT-1800E, PT-1800ECC, PT-1810, PT-1830, PT-1830SC, PT-1830VP, PT-1850, PT-1850CC, PT-1850VP, PT-1880, PT-18R, PT-18RKT, PT-18RZ, PT-1900, PT-1910, PT-1950, PT-1950VP, PT-1960, PT-2000, PT-210, PT-2100, PT-2100VP, PT-210E, PT-2110, PT-220, PT-2200, PT-2210, PT-2300, PT-2310, PT-2400, PT-2400E, PT-2400ECC, PT-2410, PT-2420, PT-2420PC, PT-2430PC, PT-2450, PT-2450CC, PT-2450DX, PT-2460, PT-2470, PT-2480, PT-2500, PT-2500C, PT-2500PC, PT-2600, PT-2610, PT-2700, PT-2700VP, PT-2710, PT-3000, PT-300B, PT-300SP, PT-310B, PT-330, PT-340, PT-35, PT-350, PT-350P, PT-3600, PT-520, PT-530, PT-540, PT-550, PT-550A, PT-580C, PT-7100, PT-7100VP, PT-7500VP, PT-7600VP, PT-900, PT-900BTS, PT-900F, PT-9200, PT-9200DX, PT-9200PC, PT-9400, PT-9500, PT-9500pc, PT-9600, PT-9800PCN, PT-D200, PT-D200BW, PT-D200BWVP, PT-D200KT, PT-D200VP, PT-D210VP, PT-D450, PT-D450VP, PT-D800W, PT-E100, PT-E100VP, PT-E500VP, PT-E550WS, PT-E550WSP, PT-E550WVP, PT-GL-100, PT-GL-200, PT-GL-200VP, PT-H100LB, PT-H100R, PT-H101, PT-H101TB, PT-H105, PT-H107, PT-H107B, PT-H110LB, PT-H200, PT-H500, PT-H75, PT-H75S, PT-P300BT, PT-P750TDI, PT-P750WSP, PT-P900, PT-ST-5 , Brother P-Touch Cube Pro PT-P910BT
Type: Tape
Brand: Brother
