Brother TZESE4 Black on White 18MM Security Tape
Quicklinx: B09SWS00 Mfr#: TZESE4
Type: Tape
30 In Stock
£26.21 ex VAT
£31.45 inc VAT
This tape features a special tell-tale adhesive. If the label is removed, a checkerboard pattern will be left behind on the item and also on the tape. This makes it easy to see when a label has been removed from a piece of property and will prevent the label from being used elsewhere. This tape is used primarily for property security applications.
  • P-touch TZ label tested to the extreme
    Extensive testing has been performed to ensure that P-touch TZ label is incredibly durable under all kinds of conditions. It holds up extraordinarily well - and stays crisp, legible and affixed - even when subjected to abrasion, extreme temperature, industrial chemicals and sunlight.
  • Abrasion resistant P-touch TZ label
    Brother's patented tape technology ensures that Brother P-touch laminated label can withstand even heavy abrasion.
  • Temperature resistant P-touch TZ label
    Whether you want to use the label in freezing conditions or extremely warm environments, Brother P-touch laminated label has been designed to last.
  • Fade resistant P-touch TZ label
    Wherever you use P-touch laminated label, it will stay as clear and legible as the day it was applied.
  • Water and chemical resistant P-touch TZ label
    Testing TZ label 'to the extreme' has found it to be waterproof and resistant to chemical spill.
Brother TZe-SE4 - security tape - 1 cassette(s) - Roll (1.8 cm x 8 m)
Security tape
Adhesive Type
Tell-tale adhesive
Media Size
Roll (1.8 cm x 8 m)
Media Colour
Black on white
Included Qty
1 cassette(s)
Compatible with
Brother PT-D600; P-Touch PT-1000, 1400, 1500, 1600, 1650, 170, 1700, 1750, 1760, 18, 1810, 1830, 1880, 1900, 1910, 1950, 1960, 2100, 2110, 2200, 2210, 2300, 2310, 2350, 2400, 2410, 2430, 2500, 2600, 2610, 2700, 2710, 3600, 550, 65, 7500, 7600, 9200, 9500, 9600, 9800, E500, E550, H500, P750, P900
Media
Media Type
Security tape
Adhesive Type
Tell-tale adhesive
Media Sizes
Roll (1.8 cm x 8 m)
Media Colour
Black on white
Included Qty
1 cassette(s)
Colour Category
White
Compatible with
Brother PT-D600 , Brother P-Touch PT-1000, PT-1000BTS, PT-1400, PT-1500pc, PT-1600, PT-1650, PT-1700, PT-170K, PT-1750, PT-1760, PT-1800, PT-1810, PT-1830, PT-1830SC, PT-1830VP, PT-1880, PT-18R, PT-18RKT, PT-18RZ, PT-1900, PT-1910, PT-1950, PT-1950VP, PT-1960, PT-2100, PT-2100VP, PT-2110, PT-2200, PT-2210, PT-2300, PT-2310, PT-2350, PT-2400, PT-2400E, PT-2400ECC, PT-2410, PT-2430PC, PT-2500, PT-2500C, PT-2500PC, PT-2600, PT-2610, PT-2700, PT-2700VP, PT-2710, PT-300, PT-310, PT-320, PT-330, PT-350, PT-350P, PT-3600, PT-520, PT-530, PT-540, PT-540C, PT-550, PT-550A, PT-580C, PT-65SB, PT-65SCCP, PT-65VP, PT-7500VP, PT-7600VP, PT-8000, PT-9200, PT-9200DX, PT-9200PC, PT-9400, PT-9500, PT-9500pc, PT-9600, PT-9800PCN, PT-E500VP, PT-E550WS, PT-E550WSP, PT-E550WVP, PT-H500, PT-P750TDI, PT-P750WSP, PT-P900
Type: Tape
Brand: Brother
