This tape features an exclusive laminated tape process and a standard adhesive. The Brother TZE631 is perfect for everyday applications and is best suited for smooth flat surfaces. Its labels stay on under normal indoor and outdoor use, including hot and cold environments.
P-touch TZ label tested to the extreme
Extensive testing has been performed to ensure that P-touch TZ label is incredibly durable under all kinds of conditions. It holds up extraordinarily well - and stays crisp, legible and affixed - even when subjected to abrasion, extreme temperature, industrial chemicals and sunlight. -
Abrasion resistant P-touch TZ label
Brother's patented tape technology ensures that Brother P-touch laminated label can withstand even heavy abrasion. -
Temperature resistant P-touch TZ label
Whether you want to use the label in freezing conditions or extremely warm environments, Brother P-touch laminated label has been designed to last. -
Fade resistant P-touch TZ label
Wherever you use P-touch laminated label, it will stay as clear and legible as the day it was applied. -
Water and chemical resistant P-touch TZ label
Testing TZ label 'to the extreme' has found it to be waterproof and resistant to chemical spill.
- Brother TZe-631 - laminated tape - 1 cassette(s) - Roll (1.2 cm x 8 m)
- Product Type
- Laminated tape
- Adhesive Type
- Standard adhesive
- Media Size
- Printing Technology
- Thermal transfer
- Media Colour
- Black on yellow
- Included Qty
- 1 cassette(s)
- Compatible with
- Brother PT-D210, D600, H110; P-Touch GL-H100, H105, PT-1000, 1005, 1010, 1080, 1090, 1100, 1190, 1230, 1280, 1290, 1760, 18, 1830, 190, 2430, 2470, 3600, 7100, 900, 9800, D200, D210, D410, D450, D460, D610, D800, E100, E500, E550, PT-GL-200, PT-H100, H101, H105, H110, H500, H75, P300, P750, P900
Media
- Media Type
- Laminated tape
- Adhesive Type
- Standard adhesive
- Media Sizes
- Thermal transfer
- Media Colour
- Black on yellow
- Included Qty
- 1 cassette(s)
- Colour Category
- Yellow
- Compatible with
- Brother PT-D210, PT-D600, PT-H110 , Brother P-Touch GL-H100, GL-H105, GL-H105VP, PT-1000, PT-1000BTS, PT-1005, PT-1005BTS, PT-1005F, PT-1005FB, PT-1010, PT-1010L, PT-1010NB, PT-1010R1, PT-1080, PT-1080BTS, PT-1080SBTS, PT-1090, PT-1090BK, PT-1100, PT-1100SB, PT-1100SBVP, PT-1100ST, PT-1130, PT-1150, PT-1150DX, PT-1160, PT-1170, PT-1170S, PT-1180, PT-1180HK, PT-1190, PT-11Q, PT-1200, PT-1200S, PT-1230PC, PT-1250, PT-1250CC, PT-1250CCVP, PT-1250J, PT-1250LB, PT-1250S, PT-1250VP, PT-1250VPS, PT-1260VP, PT-1280, PT-1280BTS, PT-1280CB, PT-1280DT, PT-1280DT (50TH Year Anniversary Model), PT-1280SR, PT-1280VP, PT-1280VPS, PT-1290, PT-1290DT, PT-1290SBVP, PT-1290VP, PT-1300, PT-1400, PT-1500pc, PT-1600, PT-1650, PT-1700, PT-1750, PT-1760, PT-1800, PT-1800 PLUS, PT-1800E, PT-1800ECC, PT-1810, PT-1830, PT-1830SC, PT-1830VP, PT-1850, PT-1850CC, PT-1850VP, PT-1880, PT-18R, PT-18RKT, PT-18RZ, PT-190, PT-1900, PT-1910, PT-1950, PT-1950VP, PT-1960, PT-200, PT-2000, PT-210, PT-2100, PT-2100VP, PT-210E, PT-2110, PT-220, PT-2200, PT-2210, PT-2300, PT-2310, PT-2400, PT-2400E, PT-2400ECC, PT-2410, PT-2420, PT-2420PC, PT-2430PC, PT-2450, PT-2450CC, PT-2450DX, PT-2460, PT-2470, PT-2480, PT-2500, PT-2500C, PT-2500PC, PT-2600, PT-2610, PT-2700, PT-2700VP, PT-2710, PT-300, PT-3000, PT-300B, PT-300SP, PT-310, PT-310B, PT-320, PT-330, PT-340, PT-350, PT-350P, PT-3600, PT-520, PT-530, PT-540, PT-550, PT-550A, PT-580C, PT-7100, PT-7100VP, PT-7500VP, PT-7600VP, PT-900, PT-900BTS, PT-900F, PT-9200, PT-9200DX, PT-9200PC, PT-9400, PT-9500, PT-9500pc, PT-9600, PT-9800PCN, PT-D200, PT-D200BW, PT-D200BWVP, PT-D200KT, PT-D200VP, PT-D210VP, PT-D410VP, PT-D450, PT-D450VP, PT-D460BTVP, PT-D610BTVP, PT-D800W, PT-E100, PT-E100VP, PT-E500VP, PT-E550WS, PT-E550WSP, PT-E550WVP, PT-GL-100, PT-GL-200, PT-GL-200VP, PT-H100LB, PT-H100R, PT-H101, PT-H101TB, PT-H105, PT-H105WB, PT-H110LB, PT-H500, PT-H75, PT-H75S, PT-P300BT, PT-P750TDI, PT-P750WSP, PT-P900, PT-ST-5
