Designed for your busy home and small offices, the affordable MFC-L3730CDN comes feature rich, with fast print speeds and built-in wired connectivity, all in a quiet and compact unit. Together with automatic 2-sided printing, you won't need to refill the paper tray as often.
Efficient connectivity
With both LAN and USB 2.0 interfaces, this device ensures seamless integration into existing networks, providing flexibility and ease of use for all office environments. -
High-quality printing
Achieve sharp, vibrant prints with a maximum resolution of 2400 x 600 DPI for both black and white and color documents, ensuring professional-quality outputs for all your business needs. -
Versatile media handling
Supports a wide range of media sizes from A4 to Legal, and types including envelopes, photo paper, and glossy paper, making it ideal for diverse printing tasks. -
Advanced scanning capabilities
Offers a high optical resolution of 1200 x 2400 DPI for scanning, with a color depth of 24-bit and internal 48-bit for capturing detailed and accurate images. -
Automatic duplexing
Saves time and paper with the ability to automatically print on both sides of the paper, perfect for creating professional-looking documents and reducing waste.
- Brother MFC-L3730CDN - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- LED (colour)
- Recommended Monthly Volume
- 300 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Copying Resolution Class
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to SharePoint, scan to OCR
- Power
- AC 230 V (50/60Hz)
- 41 cm x 47.5 cm x 41.4 cm
- 23.4 kg
- 2-year warranty
- Fax Type
- Plain paper
- LED - colour
- 300 - 1500 pages
- Display Diagonal Size
- 3.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- United Kingdom
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, Sort
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7, XPS 1.0
- First Print Out Time B/W
- 15.5 sec
- First Print Out Time Colour
- 15.5 sec
- Colour Management Features
- Mopria
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
- Scanning Resolution Details
- 1200 x 2400 dpi - flatbed , 600 x 600 dpi - ADF
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 250 stations
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- Supported Original Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), 215.9 x 300 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 19 ppm (Letter A) - colour , Printing: up to 6 spm (A4/Letter A) - B/W duplex , Printing: up to 6 spm (A4/Letter A) - colour duplex , Copying: up to 18 ppm - B/W , Copying: up to 18 ppm - colour , Scanning: up to 27 ipm - B/W , Scanning: up to 21 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, ARP, PEAP, EAP-FAST, EAP-MD5
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13, Windows 10 in S mode
- Voltage Required
- 400 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 9.7 Watt
- First Copy Out Time B/W
- 17.5 sec
- First Copy Out Time Colour
- 17.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19798 , 1 x drum - up to 18000 pages - Brother DR243CL , 1 x belt - up to 50000 pages - Brother BU223CL , 1 x waste toner collector - up to 50000 pages - Brother WT223CL
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 41 cm
- 47.5 cm
- 41.4 cm
- 23.4 kg
- Shipping Width
- 58.9 cm
- Shipping Depth
- 52.3 cm
- Shipping Height
- 56.8 cm
- Shipping Weight
- 27.6 kg
- Sound Emission
- 43 dBA (idle) / 45 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother TN243BK Toner Black | In Stock | £38.82 |
