The Brother MFC-L3710CW digital color all-in-one printer is a great option for home and small offices looking for laser printer performance that need print, copy, scan and fax functionality. Offers flexible connection options plus wireless printing from mobile devices (1). Use the 50-sheet automatic document feeder for multi-page copy, scan and fax and the manual feed slot for varied paper types and sizes. Create custom shortcuts on the 3.7" color touchscreen plus print-from and scan-to popular cloud apps.
Fast printing and scanning keeps you moving
Delivering increased efficiency with quick print speeds of up to 19 pages per minute and scan speeds up to 29ipm black and 22ipm color. -
Print professional documents in black and color
Print high-quality business documents in sharp black and rich, vivid color. -
Engineered to deliver efficiency and help increase productivity
The 250-sheet capacity paper tray adjusts for letter or legal paper to help minimize paper refills while the up to 50-sheet automatic document feeder helps save time with multi-page copy, scan & fax. -
Flexible printing options
The manual feed slot offers flexible paper handling for a variety of papers and sizes, including card stock, envelopes and more to accommodate varied printing needs. -
Printing as mobile as you are
Print wirelessly from your desktop, laptop, smartphone and tablet. -
Intuitive connection to the Cloud
Print-from and scan-to popular cloud apps directly from the 3.7" color touchscreen including Dropbox, Google Drive, Evernote, -
Connect your way
Versatile connection options with built-in wireless, and Wi-Fi Direct or connect locally to a single computer via USB interface. -
Dependable, durable and compact design
Sturdy and robust construction ensures your printer works as hard as you do; compact design is ideal for smaller spaces.
- Brother MFC-L3710CW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- LED (colour)
- Recommended Monthly Volume
- 300 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Copying Resolution Class
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SharePoint, scan to OCR, scan to image
- Power
- AC 230 V (50/60Hz)
- 41 cm x 47.5 cm x 41.4 cm
- 22.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Fax Type
- Plain paper
- LED - colour
- 300 - 1500 pages
- Display Diagonal Size
- 3.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- United Kingdom
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Sort
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7, XPS 1.0
- First Print Out Time B/W
- 15.5 sec
- First Print Out Time Colour
- 15.5 sec
- Colour Management Features
- Mopria
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
- Scanning Resolution Details
- 1200 x 2400 dpi - flatbed , 600 x 600 dpi - ADF
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 250 stations
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- Supported Original Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), 215.9 x 300 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - colour , Copying: up to 18 ppm - B/W , Copying: up to 18 ppm - colour , Scanning: up to 27 ipm - B/W , Scanning: up to 21 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B
- Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, PEAP, SNMP 3
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13, Windows 10 in S mode, macOS 10.14
- Voltage Required
- 400 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 9.7 Watt
- First Copy Out Time B/W
- 17.5 sec
- First Copy Out Time Colour
- 17.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19752 , 1 x drum - up to 18000 pages - Brother DR243CL , 1 x transfer unit - up to 50000 pages - Brother BU223CL , 1 x waste toner collector - up to 50000 pages - Brother WT223CL
- ENERGY STAR Certified
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 41 cm
- 47.5 cm
- 41.4 cm
- 22.5 kg
- Shipping Width
- 58.9 cm
- Shipping Depth
- 52.3 cm
- Shipping Height
- 56.8 cm
- Shipping Weight
- 26.7 kg
- Sound Emission
- 43 dBA (idle) / 45 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother TN243BK Toner Black | In Stock | £40.69 |
