Brother MFC 8890DW - multifunction ( fax / copier / printer / scanner ) ( B/W )
Quicklinx: 7GD7WS00 Mfr#: MFC8890DWZU1
The MFC-8890DW is the ultimate laser all-in-one solution for your business. It has an 802.11b/g wireless interface to print, scan and PC fax wirelessly without the clutter of cables. It also has a USB direct interface to print PDF or JPEG files from or scan PDF or JPEG files to your USB flash memory drive.
  • Fast printing and copying
    Produces crisp monochrome output at an impressive print and copy speed of up to 32 pages per minute.
  • Convenient walk-up printing and scanning
    A USB direct interface is located on the front of the machine for printing PDF or JPEG files from or scanning PDF or JPEG files to your USB flash memory drive.
  • Legal-size document glass
    Ample room for placing documents on the platen for scanning or copying up to legal-size documents.
Brother MFC-8890DW - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 30 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 2400 dpi
Original Size
148 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
69.9 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying)
Parallel, USB 2.0, LAN, USB host, Wi-Fi
53.1 cm x 45.1 cm x 47.5 cm
18.6 kg
Microsoft Certification
Compatible with Windows 7
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
5 lines
Standard Memory
64 MB 64 MB
Max Supported Memory
576 MB 576 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 30 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Total Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
40 station(s)
Speed Dialing
300 station(s)
Broadcast Transmission
390 stations
Fax forwarding, automatic redialing
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
69.9 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
161 g/m²
Supported Media Type
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 50 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 216 x 406.4 mm - 69.9 x 116 mm weight: 60 g/m² - 161 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 30 ppm - B/W , Copying: up to 30 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x parallel , 1 x LAN
Network Protocols
TCP/IP, LPR/LPD
Security Protocols & Features
LEAP, WEP
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Vista, Apple MacOS X 10.3.9 or later, MS Windows Server 2008
Software Included
Brother BR-Admin Professional, ScanSoft PaperPort SE 11.0, Brother MFL-Pro Suite
660 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
19 Watt
First Copy Out Time B/W
10.5 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages - Brother TN3230 , 1 x drum - up to 25000 pages - Brother DR3200
Limited warranty - 1 year - on-site
53.1 cm
45.1 cm
47.5 cm
18.6 kg
Shipping Width
62.8 cm
Shipping Depth
56.7 cm
Shipping Height
57.5 cm
Shipping Weight
21.1 kg
Sound Emission
30 dBA (idle) / 56 dBA (operating)
7GD7 Brother HL5340/5350 High Capacity Toner In Stock £106.14
7GD7 Brother TN3230 - Toner cartridge - 1 x black - 3000 pages In Stock £64.68
