The MFC-8380DN is a fast, network ready, professional all-in-one that offers a fully featured laser printer, copier, fax and color scanner. The integrated technology and fully automatic duplex function mean that documents will look professional at all times - the ideal solution for any office.
- Brother MFC-8380DN - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 30 ppm
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Scanning
- 600 x 2400 dpi
- Original Size
- 148 x 148 mm (min) - 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 20 sheets
- Media Size
- 69.9 x 116 mm (min) - 216 x 406.4 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, recycled paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB, LAN, USB host
- Office Machine Features
- Print from USB flash drive, save to USB flash drive
- 53.1 cm x 45.1 cm x 47.5 cm
- 18.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- Display
- 2 lines x 16 characters
- Interface
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 576 MB 576 MB
Copying
- Max Copying Speed
- Up to 30 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 6, IBM Proprinter, BR-Script 3
- Image Enhancement Technology
- Brother HQ1200
Scanning
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Total Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 300 station(s)
Document & Media Handling
- Min Original Size
- 148 x 148 mm
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 20 sheets
- Min Media Size
- 69.9 x 116 mm
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- 300 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets , ADF - 50 sheets , Output tray - 150 sheets , Bypass tray - 50 sheets
- Speed Details
- Copying: up to 30 ppm - B/W , Printing: up to 30 ppm - B/W , Printing: up to 9 ppm - B/W duplex
- 1 x USB , 1 x USB host , 1 x LAN
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows Vista, MS Windows 2000 Professional, Apple MacOS X 10.3.9 or later, MS Windows Server 2008
- Software Included
- Drivers & Utilities
- 680 Watt
- Power Consumption Standby
- 85 Watt
- Power Consumption Sleep
- 19 Watt
- Warm-Up Time
- 18 sec
- First Copy Out Time B/W
- 10.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 53.1 cm
- 45.1 cm
- 47.5 cm
- 18.6 kg
- Shipping Width
- 62.8 cm
- Shipping Depth
- 56.7 cm
- Shipping Height
- 57.5 cm
- Shipping Weight
- 21.1 kg
- Sound Emission
- 4.6 dB (idle) / 56 dB (operating)
Brother HL5340/5350 High Capacity Toner | In Stock | £104.60 |
Brother TN3230 - Toner cartridge - 1 x black - 3000 pages | In Stock | £64.30 |
Brother DR3200 Drum Unit | In Stock | £121.02 |
