Brother MFC 8370DN - multifunction ( fax / copier / printer / scanner ) ( B/W )
Quicklinx: 6KYBWS00 Mfr#: MFC8370DNZU1
This high quality and professional network ready all-in-one offers fast laser print, fax, copier and color scanning functions at the touch of a button. The fully automatic duplex feature allows all documents to be printed on both sides of the paper, providing professional results at all times.
Error correction mode detects errors and resends the page of the document that had the error. Ensures the receiver gets the complete document without having to resend it manually. Polling allows for a remote facsimile unit to request transmission from another unit. Also allows for user to transmit and receive documents on the same phone call.
  • Fax out of paper reception
    Allows the fax to receive documents into memory even when out of paper and to be printed direct from memory.
  • Remote access
    Allows the user to remotely access their machine by using another touch tone phone.
  • Fax retrieval
    Allows the user to retrieve fax messages using another touch tone machine.
  • Security features
    Ensures that highly sensitive documents are kept confidential.
  • Delayed transmission
    Send documents when call costs are cheaper at a later time.
  • Error correction mode
    Detects errors and resends the page of the document that had the error. Ensures the receiver gets the complete document without having to resend it manually.
  • Polling
Brother MFC-8370DN - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 28 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 2400 dpi
Original Size
148 x 148 mm (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
69.9 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Transparencies, envelopes, plain paper, recycled paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive
53.1 cm x 45.1 cm x 47.5 cm
18.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
Standard Memory
64 MB 64 MB
Copying
Max Copying Speed
Up to 28 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 6, IBM Proprinter, BR-Script 3
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Total Memory Capacity
Up to 600 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
16 station(s)
Speed Dialing
300 station(s)
Broadcast Transmission
366 stations
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
216 x 356 mm
Original Type
Sheets
20 sheets
Min Media Size
69.9 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
300 sheets
50 sheets
150 sheets
Input tray - 250 sheets , ADF - 50 sheets , Output tray - 150 sheets , Bypass tray - 50 sheets
Speed Details
Copying: up to 28 ppm - B/W , Printing: up to 28 ppm - B/W , Printing: up to 13 ppm - B/W duplex
1 x USB 2.0 , 1 x USB host , 1 x LAN
680 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
19 Watt
Warm-Up Time
18 sec
First Copy Out Time B/W
8.5 sec
ENERGY STAR Certified
Limited warranty - 1 year - on-site
53.1 cm
45.1 cm
47.5 cm
18.6 kg
Shipping Width
62.8 cm
Shipping Depth
56.7 cm
Shipping Height
57.5 cm
Shipping Weight
21.1 kg
6KYB Brother HL5340/5350 High Capacity Toner In Stock £105.12
6KYB Brother TN3230 - Toner cartridge - 1 x black - 3000 pages In Stock £64.62
6KYB Brother DR3200 Drum Unit In Stock £120.11
