Brother MFC-7225N
Brother MFC-7225N
Quicklinx: 3RRPWS00 Mfr#: MFC7225NU1
Brother is committed to providing exceptional value for customers by utilizing its accumulated technology and know-how to satisfy their needs. The company supplies unique products, for personal use in office and home that incorporate the pleasure of creation with practical functionality.
Brother MFC-7225n - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 300 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
200 x 400 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
69.9 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
Parallel, USB, LAN
AC 230 V (50/60Hz)
37.4 cm x 37.4 cm x 26.2 cm
7.3 kg
Microsoft Certification
Certified for Windows Vista
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
1 line x 16 characters
Parallel, USB, LAN
United Kingdom
Standard Memory
32 MB 32 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 300 dpi
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
99
Printing
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
PCL 6, BR-Script 3
Scanning
Optical Resolution
200 x 400 dpi
Interpolated Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Reception Memory Capacity
Up to 600 pages
Transmission Memory Capacity
Up to 600 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
10 station(s)
Speed Dialing
200 station(s)
Caller ID
Telephone / Fax Switch
Broadcast Transmission
260 stations
Fax forwarding
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Min Media Size
69.9 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
161 g/m²
Supported Media Type
250 sheets
Max Media Capacity
250 sheets
100 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) , Output tray - 100 sheets - A4 (210 x 297 mm)
Speed Details
Printing: up to 20 ppm - B/W , Copying: up to 20 ppm - B/W
1 x USB , 1 x parallel , 1 x LAN
Network Protocols
TCP/IP
AC 230 V (50/60Hz)
475 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
10 Watt
Consumables Included
1 x toner (black) - up to 2500 pages , 1 x drum - up to 12000 pages
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ISO 9001
Limited warranty - 1 year
37.4 cm
37.4 cm
26.2 cm
7.3 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
3RRP Brother TN2000 Black Toner Cartridge In Stock £62.01
3RRP Brother DR-2000 Drum In Stock £75.54
