Brother Labelling machine 176mm per second 32 Font styles 1 Year RTB
Quicklinx: CY63WS00 Mfr#: QL810WZU1
  • Windows 8 (32/64 bits)
Marketing description is not available.
  • Flexible connectivity to print from virtually anywhere
    The built-in wireless interface offers easy connectivity so you may print from virtually anywhere without being tethered to a computer. Can also share on a network.
  • Print Black/Red labels with DK-2251 labels
    Brother QL-800 series is the only office category label printer to offer the technology that lets your print two colors over the entire label!
  • Print labels wirelessly
    Use the free Brother iPrint & Label App to print labels wirelessly from your Apple iPhone, iPad, and iPod touch or Android smartphone.
Brother QL-810W - label printer - two-colour (monochrome) - direct thermal
Printer Type
Label printer - direct thermal - two-colour (monochrome)
1.12 kg
Ireland
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 110 labels/min , Up to 176 mm/sec
Max Resolution (B&W)
300 x 600 dpi
Cutter
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Barcodes
Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, GS1-128
Media Type
Die cut labels, label continuous paper
Compatible Tapes
DK tape
Fonts
Brussels, Helsinki, San Diego, Letter Gothic Bold, Brougham
Styles & Effects
Bold, normal, vertical, shadow, italic, shadow light, surround, horizontal lines, invert
Printer Features
Auto Power Off
Required 1 Lithium Ion Included Qty 0
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x, Apple macOS 10.12.x
1-year warranty
12.53 cm x 23.4 cm x 14.5 cm
Printer Type
Ireland
Printer
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
300 x 600 dpi
Fonts
Styles & Effects
Auto Cutter
Barcodes
Printer Features
Auto Power Off
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (2.9 cm), Roll (5.4 cm), Roll (1.2 cm), Roll (3.8 cm), Roll (6.2 cm), Roll (5 cm)
Max Printing Width
58 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
1 x USB 2.0
1 x USB cable
Media Included
62 mm x 5 m black/red paper tape, 29 x 90 mm black on white standart address labels (100 labels)
Power adapter - external
Frequency Required
50/60 Hz
Lithium Ion
Required Qty
1
Included
0
Software Included
Software Development Kit (SDK)
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
10 °C
35 °C
20 - 80%
12.53 cm
23.4 cm
14.5 cm
1.12 kg
Ink (6)
CY63 Brother Large Address Labels In Stock £7.84
CY63 Brother DK Continuous White Labels In Stock £13.79
CY63 Brother Shipping 62 x 100mm 300 Labels In Stock £13.63
CY63 Brother p-touch White Paper - 62mm In Stock £12.49
CY63 Brother Paper Roll (6.2 cm x 30.5 m) In Stock £10.84
CY63 Brother Non Adhesive Paper Tape 54mm In Stock £11.86
Other bundles (2)
CY63 Brother BROTHER DK-22212 TAPE 62MM WH. In Stock £35.49
CY63 Brother P-TOUCH TAPE PAPER 29MMX30.48M In Stock £6.51
