With the HL- L5100DNT, you can now have stunning results with enhanced paper handling all in one machine. Together with the added option of optional high yield toner cartridges, you can also reduce your print spend, making this machine the ideal partner in your office.
Key Features
- Fast print speeds of up to 40ppm.
- Combined paper input of 820 sheets.
- Automatic 2-sided printing.
- High-yield replacement cartridges - optional high yield 8,000 (approx) page toner cartridge.
- 1 line, 16 character backlit LCD display.
- High speed wired (10Base-T/100Base-TX/) and USB 2.0 connectivity.
Maximise Performance & Reduce Print Spend
Versatile paper handling enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional high yield toner cartridges, productivity is enhanced whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L5000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L5000 range is enabled with secure function lock 3.0, 802.1x network security and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset and Certificate Management.
Flexible print solutions from Brother
Our L5000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions can be specifically tailored to your requirements and enables you to maximise your print efficiency and minimise costs.
Eco-friendly
The L5000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
- Brother HL-L5100DNT - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 42 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 20 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- Processor
- Cortex-A9 800 MHz
- RAM Installed (Max)
- 256 MB
- Language Simulation
- PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 820 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray, 520-sheet input tray
- Networking
- Print server
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
- 37.3 cm x 38.8 cm x 38.7 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.2 sec
- Media Handling
- Processor
- Cortex-A9 800 MHz
RAM
- 256 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 820 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , 1 x automatic - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19752
- Nordic Swan
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 640 watt
- Power Consumption Stand by
- 32 watt
- Power Consumption Sleep
- 6.5 watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 52 dBA
- Sound Emission (Quiet Mode)
- 50 dBA
- 37.3 cm
- 38.8 cm
- 38.7 cm
- 14.6 kg
- Width (Shipping)
- 66.2 cm
- Depth (Shipping)
- 52.2 cm
- Height (Shipping)
- 70.2 cm
- Weight (Shipping)
- 22 kg
Brother TN-3430 Black Standard Yield Toner | In Stock | £62.27 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £107.29 |
Brother HLL6400/MFCL6900DW/T Drum Unit 30K | In Stock | £125.81 |
