The HL-5340D is a high-speed laser printer built for reliable day-in and day-out printing. It offers a fast print speed of up to 32ppm and produces crisp, high-quality output at up to 1200 x 1200 dpi resolution. The HL-5340D features automatic duplex printing for producing professional looking two-sided documents and flexible paper handling via its 300-sheet paper capacity. For lower running costs, a high-yield 8,000-page replacement toner cartridge is available.
Fast results
Operating at print speeds up to 32 pages per minute, this printer is ideal for a busy office. -
Outstanding print quality
The HL-5340D delivers up to 1200 x 1200 dpi resolution so that all of your printed materials look their best. -
Easily print two-sided documents
Produce professional-looking two-sided documents, brochures and booklets using the automatic duplex printing feature. This feature can help reduce your paper use and save money. -
Versatile paper handling
An adjustable 250-sheet capacity paper tray easily handles letter or legal size paper and a 50-sheet capacity multi-purpose tray is for printing letterhead and custom paper sizes. Add up to two optional paper trays for additional capacity. -
Straight-Through Paper Path
A convenient fold-down, 50-sheet capacity multi-purpose tray and rear paper exit provide a straight-through paper path for printing envelopes, thicker media and custom paper sizes. -
Maximum compatibility
Offering PCL6 and BR-Script3 (PostScript3) emulations, the HL-5340D can support virtually any office or graphics application.
- Brother HL-5340D - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.5 kg
- Media Size Class
- A4
- Max Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 406.4 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 13 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- Brother HQ1200
- Automatic Duplexing
- Interface
- Parallel, USB
- Processor
- NEC VR5500 300 MHz
- RAM Installed (Max)
- 16 MB (528 MB) DIMM 144-pin
- Language Simulation
- PCL 6, IBM ProPrinter XL, EPSON FX-850
- Barcodes
- Code 39, UCC/EAN-128, ISBN, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, FIM, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- System Requirements
- Linux, Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 37.1 cm x 38.4 cm x 24.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 1200 dpi
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 66 x PostScript 3 , 66 x PCL 6 , 12 x bitmapped PCL , 13 x barcode
- Barcodes
- Media Handling
- Processor
RAM
- 16 MB / 528 MB (max)
- Technology / Form Factor
- DIMM 144-pin
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 70 mm x 116 mm
- 216 mm x 406.4 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 25 pin D-Sub (DB-25)
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x drum - up to 25000 pages
- Power Device
- Power supply - internal
- 675 Watt
- Power Consumption Stand by / Sleep
- 75 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- Sound Emission (Operating)
- 54 dB
- Sound Emission (Quiet Mode)
- 35 dB
- 37.1 cm
- 38.4 cm
- 24.6 cm
- 9.5 kg
Brother HL5340/5350 High Capacity Toner | In Stock | £104.97 |
Brother TN3230 - Toner cartridge - 1 x black - 3000 pages | In Stock | £65.00 |
