Small office? You've just found your perfect printer. The HL-2130 may be small in size but it's big on efficiency with a fast 20 pages per minute print speed (the first in less than 10 seconds) to make sure you're not kept waiting. The impressive 250-sheet paper capacity saves you time too, with less need for refilling. It keeps costs down with separate drum and toner, Energy Star approved technology and also includes 12 month warranty with lifetime technical support.
You'll appreciate being able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out after only 10 seconds. Sharp, crisp text and accurate reproduction of fine detail are a given too, with the HL-2130's high print resolution for outstanding results.
With the HL-2130 high performance doesn't mean high costs. Save paper and use less toner by reducing 2, 4, 9, 16 or 25 pages onto just one A4 sheet with N-in-1 printing. Using the toner save mode can further reduce your running costs.
High print quality - and fast results
You'll appreciate being able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out after only 10 seconds. Sharp, crisp text and accurate reproduction of fine detail are a given too, with the HL-2130's high print resolution for outstanding results. -
Low running costs
With the HL-2130 high performance doesn't mean high costs. Save paper and use less toner by reducing 2, 4, 9, 16 or 25 pages onto just one A4 sheet with N-in-1 printing. Using the toner save mode can further reduce your running costs. -
Low maintenance
Spend less time restocking paper: the HL-2130 comes with a generous 250-sheet tray. Use the manual feed slot for hassle-free printing on envelopes, special paper and labels. -
Environmentally friendly
The HL-2130 has achieved a range of environmental certifications including ENERGY STAR thanks to its recycling friendly design and low power consumption.
- Brother HL-2130 - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 6.7 kg
- Media Size Class
- A4
- Max Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 69.9 mm x 116 mm
- Max Media Size (Custom)
- 215.9 mm x 406.4 mm
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Interface
- USB
- Processor
- 200 MHz
- RAM Installed (Max)
- 8 MB
- Media Type
- Envelopes, labels, plain paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.5.x, Apple MacOS X 10.4.11, Apple MacOS X 10.6.x
- 1-year warranty
- 36.8 cm x 36 cm x 18.3 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Connectivity Technology
- Wired
- Interface
- USB
- 2400 x 600 dpi
- Brother HQ1200
- First Print Out Time B/W
- 10 sec
- Media Handling
- Processor
- 200 MHz
RAM
- 8 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 69.9 mm x 116 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 220 x 406.4 mm weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 , 1 x drum - up to 12000 pages - Brother DR2200
- 421 Watt
- Power Consumption Stand by / Sleep
- 62 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Idle)
- 31 dBA
- Sound Emission (Operating)
- 53 dBA
- 36.8 cm
- 36 cm
- 18.3 cm
- 6.7 kg
- Width (Shipping)
- 47.5 cm
- Depth (Shipping)
- 45.4 cm
- Height (Shipping)
- 33.1 cm
- Weight (Shipping)
- 8 kg
Brother BRO DR2200 DRUM HL2240/2240D/ | In Stock | £60.19 |
Brother TN2010 Black Toner Cartridge 1k Yield | In Stock | £29.24 |
