Brother DCPJ725DW Wireless Colour Inkjet Multifunction
Quicklinx: 7NB1WS00 Mfr#: DCPJ725DWZU1
This compact A4 inkjet all-in-one printer provides the same professional standards you would expect in the office, with a design that will fit right in at home. It's built for work, offering fast quality printing, scanning and copying all-in-one machine. Many time and cost-saving features come as standard, such as automatic double-sided printing. Wireless network-ready out of the box means you can share the features with the whole family, and with its impressive photo quality and 20 sheet photo tray, the family might want to use it too! And having the option for low and high yield toner cartridges, and lower power consumption you can keep running costs to a minimum.
Brother DCP-J725DW - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 23 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 12 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, plain paper
Standard Media Capacity
100 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), USB host
Office Machine Features
Print from memory card, print from USB flash drive, scan to e-mail, scan to network
40.5 cm x 37.8 cm x 18 cm
9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour
Display Features
Touch screen
Standard Memory
64 MB 64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth (Internal)
36-bit
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
20 sheets
Max Media Size
Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 102 x 152 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 127 x 178 mm
Borderless Photo Sizes
A4 (210 x 297 mm)
100 sheets
50 sheets
Input tray - 100 sheets - Ledger (279 x 432 mm) , Output tray - 50 sheets , ADF - 20 sheets
Speed Details
Printing: up to 35 ppm - B/W draft , Printing: up to 27 ppm - colour draft , Copying: up to 23 ppm - B/W , Copying: up to 20 ppm - colour , Printing: 15 sec (10 x 15 cm (4"x6")) , Printing: up to 12 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host
Security Protocols & Features
LEAP, WPA-PSK, WPA2-PSK, TKIP, AES
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, Apple Mac OS X 10.5.x
Software Included
Reallusion FaceFilter Studio, Presto! PageManager 9
Direct Printing Specifications
PictBridge
Brother Paper Pack
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
40.5 cm
37.8 cm
18 cm
9 kg
Shipping Width
46.5 cm
Shipping Depth
25.5 cm
Shipping Height
46 cm
Shipping Weight
11.6 kg
Sound Emission
50 dBA (operating)
7NB1 Brother LC1240BK - Print cartridge - 1 x black - 600 pages In Stock £18.11
7NB1 Brother LC1240C - Print cartridge - 1 x cyan - 600 pages In Stock £11.59
7NB1 Brother LC1240M - Print cartridge - 1 x magenta - 600 pages In Stock £11.59
7NB1 Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages In Stock £14.00
