Aimed squarely at builders on a budget, Comrade delivers high-end features at an incredibly competitive price point. Comrade brings a sleek, no-nonsense design that's ideal for the first-time builder. Dedicated 3.5" and 2.5" drive racks offer ample expansion possibilities, as well as room for long graphics cards up to 30cm in length. Tool-free drive locking mechanisms make installing storage a breeze, while dual dust filters enable quick and easy cleanup. A SuperSpeed USB 3.0 port has also been included to save you time during file transfers. Adorned with premium touches like a powder-coated interior and an aluminum-finish BitFenix badge, Comrade is a trusty mid-tower design and an unprecedented value.
Choose your ally
Sleek and streamlined, Comrade's design appeals to those looking for an attractive, no-nonsense housing that fits in any modern environment. -
Enhanced expansion
Comrade delivers a surprisingly roomy interior that accommodates a multitude of hardware options. The dedicated 3.5" and 2.5" drive racks provide ample storage, all while allowing room for long graphics cards up to 30 cm in length. Along with seven PCI slots and three 5.25" bays, Comrade makes a great base for a modern system. -
Easy to build
Your PC should be your friend - not your foe. Comrade comes with multiple friendly features that make the building process a snap. Features like tool-free HDD trays and ODD retention mechanisms make installing your storage virtual child's play. Motherboard standoffs have already been built directly onto the motherboard tray, and the simple pull-off front panel with independent I/O module saves you even more time during installation. -
SuperSpeed USB 3.0
Connectivity With the proliferation of HD media, files are not getting any smaller. Comrade comes equipped with a SuperSpeed USB 3.0 port, perfect for quickly transferring files from external hard drives, thumb drives, and more. -
Incredible extras
Despite the low price tag, Comrade is loaded with features that are normally seen in much more pricey cases. Dual removable dust filters help keep the internals of the system dust-free, and are extremely easy to wash. Rolled-edge cables pass-through help protect your cabling, and a powder coated interior and aluminum BitFenix logo give Comrade a premium quality look.
- BitFenix Comrade - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- White
- I/O Connectors
- 1 x USB 2.0 , 1 x USB 3.0 , 2 x audio
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless drive bays, front dust filter, cable management holes, bottom mounted PSU holder
- Power Device
- No power supply (ATX / PS/2)
- 18.5 cm x 47.05 cm x 42.855 cm
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 6
- Front Accessible Bays Qty
- 3
- White
- Cooling System
- Front: 120 mm fan mount x 2 , Rear: 120 mm fan x 1
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 2.5" , 3 (total) / 3 (free) x internal - 3.5"
- Expansion Slots
- 7
- 1 x USB 2.0 , 1 x USB 3.0 , 2 x audio - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- Max Supported Qty
- 1
- 18.5 cm
- 47.05 cm
- 42.855 cm
