Maximum Performance Dual-band Router
Featured with simultaneous dual-band technology, the BiPAC 7800DXL can run both 2.4GHz and 5GHz frequency bands at the same time, offering ultra-fast wireless speeds of up to 600Mbps and multiple SSIDs on both bands. The BiPAC 7800DXL, by adopting this state-of-the-art technology, allows for multiple-demand applications, such as streaming HD videos and multiplayer gaming simultaneously. With an integrated 802.11n Wireless Access Point, the router delivers up to 6 times the speed of an 802.11a/b/g network device. It supports a data rate of up to 600Mbps (2.4GHz and 5GHz) and is also compatible with 802.11a/b/g equipment. The Wireless Protected Access (WPA-PSK/WPA2-PSK) and Wireless Encryption Protocol (WEP) features enhance the level of transmission security and access control over wireless LAN. The router also supports the Wi-Fi Protected Setup (WPS) standard, allowing users to establish a secure wireless network by simply pushing a button. If your network requires wider coverage, the built-in Wireless Distribution System (WDS) repeater function allows you to expand your wireless network without the need for any external wires or cables.
3G/4G Mobility and Always-On Connectivity
With the BiPAC 7800DXL you can connect a 3G/4G LTE USB modem to its built-in USB port, allowing you to watch movies, download music or access e-mail no matter where you may be. You can even share your Internet connection with others, when away on business, at a show, or wherever there is mobile signal but no fixed line access. The auto fail-over feature ensures maximum connectivity and minimum interruption by quickly and smoothly connecting to a 3G/4G LTE network in the event that your ADSL/fibre/cable line fails. The BiPAC 7800DXL will then automatically reconnect to the ADSL/fibre/cable connection when it's restored, reducing connection costs. These features are perfect for office situations where a constant and uninterrupted connection is critical.
Experience Gigabit
The BiPAC 7800DXL has four Gigabit LAN ports and the fourth port can be configured as a WAN port if required. This EWAN offers another broadband connectivity option for connecting to a cable, VDSL, fibre or second ADSL modem. The BiPAC 7800DXL again offers users convenience and optimal network performance with data rates reaching up to 1Gbps.
Pathway to the Future
The BiPAC 7800DXL fully supports IPv6 (Internet Protocol Version 6), launched as the current IPv4 range is filling up, and IPv6 is gradually becoming the indispensable addressing system for savvy cloud computing users. Dual stack means the router is capable of running IPv4 and IPv6 in parallel during the transition period. With Billion IPv6 enabled devices, three major transition mechanisms such as Dual-Stack, Dual-Stack Lite, and 6RD (IPv6 rapid deployment) are supported to be adapted easily into service provider's IPv4/IPv6 network.
Maximum performance dual-band router
Featured with simultaneous dual-band technology, the BiPAC 7800DXL offers ultra-fast wireless speeds and multiple SSIDs on both bands. The BiPAC 7800DXL, by adopting this state-of-the-art technology, allows for multiple-demand applications, such as streaming HD videos and multiplayer gaming simultaneously. With an integrated wireless access point, the router delivers the high speed. The router also supports the Wi-Fi protected setup (WPS) standard, allowing users to establish a secure wireless network by simply pushing a button. If your network requires wider coverage, the built-in wireless distribution system (WDS) repeater function allows you to expand your wireless network without the need for any external wires or cables. -
3G/4G mobility and always-on connectivity
With the BiPAC 7800DXL you can connect a 3G/4G LTE USB modem to its built-in USB port, allowing you to watch movies, download music or access e-mail no matter where you may be. You can even share your Internet connection with others, when away on business, at a show, or wherever there is mobile signal but no fixed line access. The auto fail-over feature ensures maximum connectivity and minimum interruption by quickly and smoothly connecting to a 3G/4G LTE network. -
Experience Gigabit
The BiPAC 7800DXL has four Gigabit LAN ports and the fourth port can be configured as a WAN port if required. This EWAN offers another broadband connectivity option for connecting to a cable, VDSL, fibre or second ADSL modem. The BiPAC 7800DXL again offers users convenience and optimal network performance with high data rates. -
Pathway to the future
With Billion IPv6 enabled devices, three major transition mechanisms are supported to be adapted easily into service provider's IPv4/IPv6 network.
- Billion BIPAC 7800DXL - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- PPPoE, PPPoA, AAL5, DHCP, DNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP
- Firewall protection, DMZ port, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, dynamic DNS server, DiffServ support, MAC address filtering, Wireless Distribution System (WDS) support, URL filtering, firmware upgradable, SNTP support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS)
- ANSI T1.413, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- 23 cm x 15.5 cm x 4.3 cm
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- Status Indicators
- Power, link/activity
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5
- Max Transfer Rate
- 24 Mbps
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- 23 cm
- 15.5 cm
- 4.3 cm
- 0 °C
- 40 °C
- 20 - 95% (non-condensing)
