The base unit can be mounted safely onto a wall, giving maximum flexibility and saving valuable classroom space. An indent on the back of the unit makes mounting and aligning simple. When the desired position is achieved, the unit can be screwed into the bracket mount, locking it into place.
Space-saving specialist
The base unit can be mounted safely onto a wall, giving maximum flexibility and saving valuable classroom space. -
Safe and easy mounting
- Belkin bracket - for charging station
- Product Type
- Bracket - wall-mountable
- 12.07 cm 39.11 cm
- Recommended Use
- Charging station
- 12.07 cm
- 39.11 cm
AV Furniture
- Bracket
- Recommended Use
- Charging station
- Placing / Mounting
- Wall-mountable
