Pro 4 Spotlight Camera
Connect and control with your favourite smart assistant.
Works with Alexa, Apple Homekit and Google Assistant (Works with Apple Homekit when paired with an Arlo base station.)
Connect Direct to WIFI
No base station required - simply connect to your 2.4Ghz wifi network for the camera to work.
160° Field of View
Focus on the most vulnerable parts of your property with wide-angle 160-degree viewing.
2K-video with HDR
Superior image quality and 12x zoom with 2K HDR video that lets you capture important details with clarity.
Integrated Spotlight
A powerful spotlight lets you see important details even at night and helps deter intruders.
Built-in Siren
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
Colour Night Vision
Capture important information, even at night with vivid colour night vision.
Wire-free & Weather Resistant
100% wire-free and weather resistant for instant protection you can rely on.
3-month Arlo Smart trial included
With Arlo SMART security, the Pro 4 Spotlight camera lets you monitor and verify the security of you home. Enhanced detection features powered by artificial intelligence allows you to effectively distinguish people from pets - enabling you to choose what the camera keeps an eye on.
Stay better informed with a closer look
2K HDR video lets you see clearer details and color, and zoom in on moving objects with clarity. -
Never miss a thing with a wider view
A wider 160° viewing angle ensures you have the best view of your property, no matter where you place Pro 4. -
See who's there in color, even at night
Capture the full picture in low light with color night vision. -
Spot unique details in dark areas
The integrated spotlight turns on whenever motion is detected. -
Weather-resistant for year-round security
Certified to withstand heat, cold, rain or sun. -
Keep setup fast and easy
The magnetic mount makes it simple to install and adjust your camera, wire-free. -
More power options for flexibility
Choose from the optional magnetic charging cable for continuous power, or the solar panel to charge your camera with direct sunlight. -
Charge less with a long-lasting battery
Get 6 months of battery life on one charge using the convenient rechargeable battery. -
Connects directly to Wi-Fi
Pro 4 works with your home's existing Wi-Fi network, so you won't need a separate hub. -
Respond to visitors, from anywhere
Hear and speak to visitors clearly with 2-way audio right on your phone. -
Quickly deter unwanted guests
Trigger the built-in smart siren automatically or manually from the Arlo app.
- Arlo Pro 4 - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - weatherproof
- Packaged Quantity
- 2 (specifications are for single item)
- Audio
- Yes: two-way audio capability, built-in microphone
- Camera Mount Type
- Wall mount
- 8.9 cm x 5.2 cm x 7.84 cm
- 316 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 720p, 1080p, 2K
- Optical Sensor Type
- 1/3" - 4 MP
- USB 2.0 IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi
- Cables Included
- Magnetic charging cable
- Voltage
- AC 100-240 V, DC 5 V
- Auto tracking, High Dynamic Range (HDR), 160° field of view, built-in spotlight, 130-degree motion detection angle
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C
- Packaged Quantity
- Audio Support
- Camera Mount Type
- Wall mount
- Wired, wireless
- 8.9 cm
- 5.2 cm
- 7.84 cm
- 316 g
Camera
- Colour - Day&Night - fixed - outdoor, indoor - weatherproof
- Digital Video Format
- H.264, H.265
- Max Digital Video Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 720p, 1080p, 2K
- Digital Zoom
- 12
- Infrared LEDs
- 2
Image Sensor
- 4 MP 1/3"
- Network Interface
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi
- Computer Interface
- USB 2.0
- Included Accessories
- Wall mount kit, screw kit, rechargeable battery, video monitoring decal
- Cables Included
- IC, FCC, RoHS, WERCS, EuP1275
- White
- Power Requirements
- DC 5 V
- Power Device
- AC 100-240 V (50/60 Hz)
- Battery
- 1 (up to 6 months)
- Limited warranty - 1 year
- -20 °C
- 45 °C
