Arlo Essential 2K Outdoor 2-Pack
Quicklinx: HM90WS00 Mfr#: VMC3250-100EUS
£166.66 ex VAT
£199.99 inc VAT
The 4-in-1 security camera to help make your home feel safer. Install in minutes and get a wireless video system that lets you stream live 2K colour video night and day. Or choose an Arlo Secure Subscription (sold separately) to save video clips in the cloud and look back at them anytime in the app. Our compact camera instantly detects motion and lets you speak to visitors with two-way audio or scare away trespasser with the built-in intruder alarm and motion spotlight.
Realistic Video
2K resolution gives you realistic video so you can see what's happening around your home.
Field of View
Wide 130° field of view means large areas of your home, garden or driveway are covered.
Colour Night Vision
Accurately see what’s happening at your home in vivid colour even in the dark with 2K colour night-vision.
Real-time Talk
Built in speaker & microphone lets you speak to family and visitors or warn off intruders as if you were there yourself.
Powerful Spotlight
Light up 7m of your property with bright spotlight. Have it come on automatically when motion is detected or turn it on manually from the app to make it harder for intruders to hide.
Multi-camera kits for added protection
Choose a multi-camera kit to protect more areas of your property, from garden shed to driveway.
Loud Siren
Scare off intruders with the built-in 80 db smart siren that can be heard up to 30 metres away. Have it automatically go-off if motion is detected or trigger from the app to quickly raise the alarm.
Privacy Zones
At Arlo we take privacy seriously. We know that every home is different and there may be areas around your property you do not want to video. That’s why the Arlo Essential Outdoor comes with Privacy Zones. Block out areas from your cameras field of view that you do not want to record - from neighbours front gardens to public paths. Keeping you, and those around you safer. (Available from April 2024.)
  • Weather-resistant security
    Arlo Essential is designed to withstand heat, cold, rain, and sun.
  • See in colour, even at night
    Ward off intruders and view unique details in colour with the integrated spotlight.
  • Quickly install
    Set your wire-free camera in just a few easy steps.
  • Deter intruders with built-in siren
    Trigger your siren automatically, or manually from your phone.
  • Get alerts when motion is detected
    Take quick action and view live video, sound the siren, or call a friend directly from your phone.
Arlo Essential - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - weather resistant
Packaged Quantity
2 (specifications are for single item)
Audio
Yes: two-way audio capability, built-in microphone, built-in speaker
Camera Mount Type
Wall mount
5.305 cm x 5.932 cm x 9.337 cm
203 g
Wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Motion Detection
Video Modes
2K, 1080p, 720p
Optical Sensor Type
1/2.7" - 4 MP
Wi-Fi
Platform
Google Home
Intelligent Assistant
Alexa, Google Assistant
Colour Night Vision, built-in siren, built-in spotlight, RGB status LED, PIR detection
1-year warranty
Environmental Parameters (operating)
-20 °C - 45 °C
Packaged Quantity
Audio Support
Camera Mount Type
Wall mount
Wireless
5.305 cm
5.932 cm
9.337 cm
203 g
Camera
Colour - Day&Night - fixed - indoor, outdoor - weather resistant
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
2K, 1080p, 720p
Digital Zoom
12
Infrared LEDs
2
Digital Video Capture Resolution
2560 x 1440
Image Sensor
4 MP 1/2.7"
Lens Construction
Diagonal Field of View (degree)
130
Network Interface
Wi-Fi
Charging cable, wall mount kit
Lithium Ion 4650 mAh (up to 4 months)
Internet of Things (IoT)
Platform
Google Home
Compatible Application
IFTTT App
Limited warranty - 1 year
-20 °C
45 °C
Type: Home security system
Type: Outdoor Camera
Compatible With: Alexa
Brand: Arlo
