The Arlo Essential solar panel charger is a power device designed for smart security cameras. This solar panel charger is an eco-friendly solution to keep your security system operational. With its wall-mountable feature, it offers an effortless installation process, allowing you to place it in optimal sunlight exposure areas for continuous charging. Eliminate the hassle of manual charging with a seamless, efficient way to power your smart security cameras.
Eco-friendly charging
Designed specifically for smart security cameras, the Arlo Essential solar panel charger offers an eco-friendly way to keep your devices powered. With its wall-mountable feature, it seamlessly integrates into your home's exterior, ensuring your security system remains charged without the need for manual intervention. -
Effortless installation
The Arlo Essential solar panel charger is designed for easy setup. Wall-mountable and engineered for the outdoors, it provides a hassle-free solution to power your smart security cameras, ensuring continuous operation and peace of mind.
- Arlo Essential solar panel
- Product Type
- Solar panel
- Designed For
- Smart security camera
- P/N: VMC2250-111EUS
- Product Type
- Solar panel
- Designed For
- Wall mountable
- Included Accessories
- Wall mount, screw set
- Designed For
