Arlo Ultra 2 Security System - 2 Camera Kit
Quicklinx: G850WS00 Mfr#: VMS5240-200EUS
Type: Indoor / Outdoor Camera
Compatible With: Alexa
£524.99 ex VAT
£629.98 inc VAT
Enjoy the peace of mind that comes from knowing your home is safe and secure. Built with advanced 4K resolution and a wider field of view, Arlo Ultra 2 provides powerful, wire-free security to protect your loved ones.
4K Video with HDR:
Zoom in up to 12x to see sharp details with Arlo Ultra’s 4K & HDR advanced image quality technology.
Enhanced night vision:
Color night vision lets you see key details even in the dark
180 degree diagonal field of view:
See more with a wider angle lens that has auto image correction reducing the fish eye effect.
Integrated spotlight:
Scare off unwelcome guests using Arlo Ultra’s motion-activated spotlight.
Weather-resistant
Built to withstand heat, cold, rain or sun.
Versatile magnetic charging.
The magnetic charging cable snaps into place for continuous power all day.
100% wire-free with 6-month battery life
100% wire-free with 6-month battery life on one charge you can easily install your camera to watch over the most vulnerable parts of your property.
Premium 2-way Audio:
Listen and speak to visitors with crystal clear, full 2-way audio that reduces wind and noise
Built-in smart siren:
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
  • Stay better informed with clearer details
    Thanks to advanced 4K resolution with HDR, watch and record video with picture-perfect detail and color.
  • See who's there in color, even at night
    Capture the full picture in low light with enhanced color night vision.
  • Never miss a thing with an ultra-wide view
    The wider-angle lens gives you an ultra-wide 180° view of your property, while auto-correcting the image to remove fisheye distortion.
  • Enjoy peace of mind when it's dark
    Ward off would-be intruders by activating the integrated spotlight manually, or automatically when motion is detected.
  • Pick up hard-to-see details with a closer look
    Zoom in on video up to 12x closer with amazing clarity.
  • Weather-resistant for year-round security
    Designed to withstand heat, cold, rain, or sun.
  • Keep setup fast and easy
    Quickly install and adjust your camera in more ways, wire-free, using the magnetic mounts.
  • Versatile magnetic charging
  • Charge less with a long-lasting battery
    Get 6 months of battery life on one charge using the convenient rechargeable battery.
  • Respond to visitors, from anywhere
    Listen and speak to visitors from your phone with crystal-clear, 2-way audio that reduces wind and noise.
  • Quickly deter unwanted guests
    Trigger the built-in smart siren automatically or manually from the Arlo app.
Arlo Ultra 2 Security System - gateway + camera(s) - wireless (802.11b, 802.11g, 802.11n, 802.11ac, Bluetooth 4.2 LE)
System
Gateway + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 LE
Camera
2 cameras - outdoor - night vision
Platform
Google Home, Apple HomeKit, SmartThings
Intelligent Assistant
Alexa
White
Europe
1 year
System
Network Interface
microSD card slot, motion detection, 4K Ultra HD video, High Dynamic Range (HDR), two-way audio support, spotlight, 12x digital zoom, built-in siren, colour night vision, weather-resistant
Package Content
2 cameras, power adapter, 2 rechargeable batteries, magnetic charging cable, camera wall mount, screw kit, SmartHub, video monitoring decal
Network cable - 1 pcs.
White
Europe
Warranty
1 year
Cameras
Quantity
2 cameras
Camera Type
Outdoor
Sensor
1/2" - 8 Megapixel
Field of View
180°
Night Vision
Voltage
DC 5 V
Current Consumption
2 A
-20 °C
45 °C
Internet of Things (IoT)
Platform
Compatible Application
IFTTT App
Alexa
Details
Camera: 5.2 cm x 8.9 cm x 7.84 cm - 331 g , Gateway: 14 cm x 5.24 cm x 15.3 cm - 300 g
Brand: Arlo
Price Range Ex VAT: £500 - £750
