Allied Telesis  8 Port 10/100Mbps Unmanaged PoE Switch
Quicklinx: CR6FWS00 Mfr#: AT-FS708LE/POE-30
The AT-FS708LE/POE eco-friendly switch demonstrates the Allied Telesis commitment to environmentally friendly processes and products, minimizing power consumption through the use of a high-efficiency power supply and a low-power chipset. With a low power consumption and switch power-scaling to scale traffic load - as well as other power-saving features included as standard - the Allied Telesis FS708LE/ POE truly lives up to its name as an eco-friendly switch. Not only does this help the planet by reducing the carbon footprint of each switch, it also lowers the Total Cost of Ownership (TCO) to the user, as the product costs less to run and boasts a high level of reliability.
  • High performance
    Providing powerful 10/100 switching solutions for desktop, conference room, and security applications, the AT-FS708LE/POE unmanaged switch features automatic detection and classification of an attached PoE device. This is the perfect solution for a wireless security or conference room application. The 10/100 ports on the switch feature full auto-negotiation. These ports enable the switches to detect the speed and duplex modes of attached devices, enabling them to automatically configure for great performance.
  • Simplified installation
    Fully auto-configuring, the AT-FS708LE/POE switch requires minimal set-up by the user. Autosensing ports enable seamless and simple connectivity between existing 10 Mbps Ethernet and 100 Mbps Fast Ethernet UTP devices - and all units can be installed in minutes. The switch is equipped with auto MDI/MDI-X across all ports for simple connection to other hubs and switches as well as automatic detection and classification of the PoE ports. Finally, easy-to-read top panel LEDs show ongoing switch status and simplify troubleshooting.
Allied Telesis AT FS708LE/POE - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 (4 PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
30 W
Performance
Throughput: 1.19 Mpps , Switching capacity: 1.6 Gbps
MAC Address Table Size
1K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, fanless, Energy Efficient Ethernet, 96KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
17.1 cm x 9.8 cm x 2.9 cm
430 g
United Kingdom
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 (4 PoE)
PoE
PoE Budget
30 W
Performance
1K entries
Status Indicators
Port transmission speed, port duplex mode, power, PoE, link/activity
4 x 100Base-TX RJ-45 PoE , 4 x 100Base-TX RJ-45
External power adapter
39.2 Watt
UL, TUV, C-Tick, EN 60950, EN55022, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN55022 Class B, FCC Part 15, CSA 22.2, VCCI Class B
United Kingdom
17.1 cm
9.8 cm
2.9 cm
430 g
10 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
