Akasa Newton L Fanless solid Ali case for Intel NUC
Quicklinx: B70PWS00 Mfr#: A-NUC12-M1B
Newton L compact fanless case for Intel® NUC with Celeron® Processor support 2.5" SATA HDD / SSD
  • Aluminium fanless CPU cooling design
  • Ideal for business and education environments
  • Support IR remote function
  • Compatible with the following Intel® NUC Board - BLKDN2820FYB / DN2820FYKH
Specification
  • Material Aluminium
  • Motherboards types UCFF 4" X 4"
  • Motherboard support BLKNUC4c-FYB (DN2820FYKH)
  • Dimensions 140 x 111 x 51mm (W x D x H)
  • Drive bays 2.5" SSD/HDD
  • Front I/O USB 3.0 port opening, IR receiver opening
  • Antenna fitting holes 2
  • Security Kensington lock
  • VESA mounting Support
  • Optional power adaptor AK-PK36-02CM
  • Product code A-NUC12-A1B
Akasa Newton L - USFF - UCFF
System cabinet
Ultra small form factor
I/O Connectors
1 x USB 3.0
System Cabinet Features
VESA mounting interface, Kensington lock support
No power supply
14 cm x 11.1 cm x 5.1 cm
Max Mainboard Size
UCFF
Product Material
Aluminium
Expansion Bays
Internal - 2.5"
1 x USB 3.0
No power supply
14 cm
11.1 cm
5.1 cm
