Enigma takes full advantage of the Mini-ITX form factor. Superb engineering has created a case that contains space for a 5.25" optical drive and internal power adapter.
The design incorporates the limited size while maintaining a modern aesthetic. Cooling performance has not been compromised. The smooth finish front panel gives it a touch of class, with easy access front I/O ports including HD audio.
The compact design is compatible with most available Mini-ITX motherboards making it a multi-function case perfect for home or professional use. It can be part of a domestic entertainment system streaming high quality video and music around your house or providing Internet access in your living room.
- Akasa ENIGMA - USFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Ultra small form factor
- Black
- Localisation
- United Kingdom
- I/O Connectors
- 1 x USB 2.0 , 2 x audio
- Installed Fans Qty
- 1
- Supported Motherboards
- Mini-ITX
- Power Device
- Power adapter 80 Watt
- 23 cm x 21 cm x 6.5 cm
- Form Factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 1
- Front Accessible Bays Qty
- 1
- Black
- Fans
- 1 x 4 cm - (1 installed)
- Localisation
- United Kingdom
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 1 (total) / 1 (free) x internal - 2.5"
- 1 x USB 2.0 , 2 x audio - mini-jack
- Power Device
- Power adapter
- Power Provided
- 80 Watt
- 23 cm
- 21 cm
- 6.5 cm
