Acer DV653bmidv 65" 1920x1080 DVI HDMI LED Large Format Display
Quicklinx: DN29WS00 Mfr#: UM.ND0EE.009
  • 1080p
Acer DV653bmidv 65" Class LED digital signage display.
Acer DV653bmidv 65" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), RCA (composite)
VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Speaker System
2 speakers
USB
Remote control, wireless remote control
Voltage
Energy Class
Class A
226 Watt
Power Consumption (On mode)
126 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
184 kWh
146.3 cm x 7 cm x 84.4 cm
24 kg
3-year warranty
Energy Class
Class A
226 Watt
126 W
184 kWh
Diagonal Class
65"
Commercial Use
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
146.3 cm
7 cm
84.4 cm
24 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Speakers
2 x main channel speaker - 5 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
USB , Composite video input , VGA input , DVI-D input , DVI-D output , 2 x HDMI , Audio line-in , Audio line-out , LAN , Serial input , Serial output , Infrared input , Infrared output
Wireless remote control
VGA cable , HDMI cable , DVI cable
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
