The 3Com Switch 4200G is an affordable, managed entry-level Gigabit switch, perfect for cost-conscious medium-sized businesses wanting a fast, efficient network upgrade. Layer 2 switching along with Layer 3 static routing make the Switch 4200G ideal for wiring closet and workgroup connectivity.
It delivers quad-speed performance - 10/100/1000 and 10-Gigabit Ethernet. The Switch 4200G features 20 auto-negotiating 10/100/1000 ports configured as auto-MDI/MDIX, four dual-personality 10/100/1000 or SFP Gigabit ports, and two 10-Gigabit slots. Up to 32 devices can be clustered together for easy administration. Power over Ethernet is supported on all 10/100/1000 ports.
QoS and traffic management features help ensure essential applications get the appropriate priority for efficient utilization of network resources. Furthermore, this switch has enterprise-class security features including IEEE 802.1X network login, SSH/SSL encrypted device log-in, and Access Control Lists. IEEE8023af Power over Ethernet supports convergence-ready networking, with all 24 ports at full 15.4W standard power.
- 3Com Switch 4200G PWR - switch - 24 ports - Managed
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE) + 4 x shared SFP + 2 x XENPAK
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 8K entries
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH-2
- Full duplex capability, Layer 2 switching, PoE, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, ACL support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44.2 cm x 43 cm x 4.4 cm
- 6.9 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- 8K entries
- Max Units In A Stack
- 16
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- MD5, SSL, TLS, PEAP
- Authentication Method
- RADIUS, PAP, CHAP, Secure Shell v.2 (SSH2)
- Status Indicators
- Port status, power
- 1 x console management , 24 x 1000Base-T RJ-45 PoE , 4 x SFP (mini-GBIC) , 2 x XENPAK
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- FCC Class A certified, CISPR 22 Class A, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, FCC Part 15, ICES-003 Class A, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1
- Localisation
- United Kingdom
- 44.2 cm
- 43 cm
- 4.4 cm
- 6.9 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 95%
