Like most recent power supplies, this Xilence Power PSU is fitted with a 120mm fan. This produces higher airflow at lower noise levels compared to a 80mm fan. The noise levels generated by these PSUs are very favourable. Starting from just 19.5 dB(A) and reaching a maximum of only 24 dB(A), meaning that this power supplies remains very quiet even when under high load.
This 480W PSU is ideal for mid range systems and is supplied with one 6-pin PCI-E connector. The PSU also features Molex plug easy-grip connectors, allowing the user to remove any plug with little hassle. See the specification table below for a full list of available connectors.
Specifications - Model Number:XP480-12R
ATX12V Version:v2.0
20-pin ATX Connector:Yes
24-pin ATX Connector:Yes
ATX12V (4-pin) support:Yes
EPS12V (8-pin) support:Yes
PCI-E support (6-pin):Yes
Number of floppy drive connectors:1
Number of hard drive connectors:2
Number of SATA power connectors:4
Master power on/off switch:Yes
Acoustic noise level:20 to 24 dB(A)
Fan size:135mm
Mains input voltage selection:Full-range
Length of motherboard power cable:45 cm (approx)
+3.3V maximum output current:32 A
+5V maximum output current:31 A
Total +12V maximum output current:31 A
+12V1 maximum output current:15 A
+12V2 maximum output current:16 A
+12V3 maximum output current:-
+12V4 maximum output current:-
+5VSB maximum standby current:2.0 A
Mains input voltage:115-230 VAC, 50-60 Hz
Physical dimensions:Standard ATX (86 x 150 x 140 mm)
Fan speed control:Temperature Controlled
Certificates:CE
Monitor pass-through power socket:No
Customer reviews
Write a review for the Xilence XP480-12R Power 480W Quiet PSU here!
Replaced an Alienware failed PSU with this
Reviewed by Matt. Review Posted 12/03/2009
Absolutely perfect in every way. Easy fit, well packaged, good price. Went in like a dream, nice length of cables for a large case with good solid connectors.
Felt like a more expensive PSU thats for sure.
Highly recommended at this stage - hope it lasts!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
