Eaton 9PX ModularEasy 5000i or 6000i
Quicklinx: CBNSWS00 Mfr#: 9PXMEZ6Ki
£1,142.27 ex VAT
£1,370.72 inc VAT
For parallel and redundant operations with the Eaton 9x.
  • Graphical LCD display
    It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing.
  • Availability and flexibility
    The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems.
  • Paralleling functionality
    Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology!
  • Load segment control
    It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
Eaton 9PX 9PX ModularEasy 6000i - power control unit
Power control unit
Power control unit
Brand: Eaton
Price Range Ex VAT: £1000 - £1500
