D-Link 770 W AC modular power supply with front-to-back airflow
Quicklinx: J7K4WS00 Mfr#: DXS-PWR700AC
Power Rating: 770watt
£626.90 ex VAT
£752.28 inc VAT
The D-Link DXS-PWR700AC power supply is engineered to meet the rigorous power demands of network hardware. With a substantial 770 W power output, it ensures your systems run smoothly under various operational conditions. The power supply is designed with a focus on efficiency and reliability, featuring a front to rear airflow mechanism that helps maintain optimal temperatures and prolong the lifespan of your equipment. It supports a broad voltage input range from AC 100-240 V, making it versatile for global use. Additionally, its compatibility with PC network hardware makes it a flexible solution for a wide array of setups. Whether upgrading existing infrastructure or setting up new installations, the DXS-PWR700AC offers a dependable power source for your network hardware.
  • Efficient power supply
    Designed for network hardware, the DXS-PWR700AC provides a robust power solution with a 770 W output, ensuring reliable performance and operational stability.
  • Optimized airflow design
    Featuring a front to rear airflow, this power supply maintains optimal operating temperatures, promoting longevity and consistent performance.
  • Versatile compatibility
    With its internal form factor and compatibility with PC network hardware, the DXS-PWR700AC offers seamless integration for a wide range of systems.
D-Link DXS-PWR700AC - power supply - 770 watt
Power supply - internal
Input Voltage
AC 100-240 V
Power Capacity
770 watt
DXS 3610-54S, 3610-54T
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Max Electric Current
10 A
Power Capacity
770 watt
Front to rear airflow
D-Link DXS 3610-54S, 3610-54T
Brand: D-Link
Price Range Ex VAT: £500 - £750
