Powerful and efficient during warfare and a master of weapons - what is it that you expect from your power supply's nowadays. Tauro series PSUs will become your new heroes. Extreme efficient, meshed cable management, stability on all rails, low noise and 80 plus Bronze certification are some of advantages of our new PSUs.
- Quiet, stable, and efficient power supply with 80Plus Bronze certificate.
- Very stable voltage regulation and very clean DC output quality.
- 12V single rail with high compatibility to support high-end system configuration.
- Over 85% efficiency and meet official 80Plus Bronze certificate.
- Highly compatibility by single 12V rail for high-end system configuration.
- Great DC output quality by low ripple noise and low voltage regulation.
- Stable and continuous output in 50°C ambient temperature.
- Low noise by thermal fan controlled 13.5cm silent fan and two voltage synchronized 3pin connetors.
- Universal AC input by active PFC and up to 0.99 PF rate.
- Compliant with latest EU ErP Direction.
- Fully safety certificate with CE, FCC, TUV, and UL.
- Complete electric protection by OVP, OCP, UVP, OTP, OPP, and SCP.
- XIGMATEK Tauro XTK-TB-0600A - power supply - 600 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX
- 80 PLUS Certification
- 80 PLUS Bronze
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- +3.3V - 24 A / 0.5 A , +5V - 30 A / 0.5 A , +12V - 36 A / 1 A , -12V - 0.5 A / 0 A , +5VSB - 2.5 A / 0.1 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 8 x 15 pin Serial ATA power
- Modular Cable Management
- Cooling System
- 140 mm fan
- 15 cm x 16 cm x 8.6 cm
- ATX
- PSU Form Factor
- ATX
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- Efficiency
- 85%
- 80 PLUS Bronze
- Cables Included
- Power cable - external
- MTBF
- 100,000 hours
- Cooling System
- 140 mm fan
- Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, thermal protection
- UL, TUV, FCC, ERP
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 28.72 dBA
- 15 cm
- 16 cm
- 8.6 cm
