The My Passport portable drive is trusted to store the massive amounts of photos, videos and music you love. It fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
Auto backup
Automatically back up photos, videos, music and documents from your system onto your My Passport drive. Set it to your schedule. Just pick the time and frequency. -
Password protection
Built-in hardware encryption helps keep your content private and safe. Easily add a return-if-found message as the password prompt in case your My Passport drive ever gets lost. Even great minds like yours can accidentally leave things behind. -
Easy to use
Ready to use out of the box, you can start transferring files, saving memories and backing up right away.
- WD My Passport WDBS4B0020BWT - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Password authentication, automatic backup
- Power Source
- USB bus
- Enclosure Colour
- White
- 110 mm x 81.5 mm x 13.8 mm
- 170 g
- Localisation
- Worldwide (excluding China)
- 3-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Interface
- USB 3.0
- 110 mm
- 81.5 mm
- 13.8 mm
- 170 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- WD Security, WD Drive Utilities, WD Backup, WD Discovery
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Cables Included
- 1 x USB 3.0 cable - external
- Directive 2002/95/EC
- Enclosure Colour
- White
- Localisation
- Limited warranty - 3 years
- 5 °C
- 35 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 65 °C
- 20 - 80%
