Generic WD 16TB My Book Duo USB 3.1 Gen1 RAID-0 2-bay External Drive
Quicklinx: D4JXWS00 Mfr#: WDBFBE0160JBK-EESN#SP
Form Factor: 3.5
Capacity: 16TB
Interface: USB 3.1
£426.42 ex VAT
£511.70 inc VAT
Transfer, save and protect your photos, videos, music and other massive files to free up valuable space on your computers. Featuring blazing-fast transfer speeds, hardware RAID and password protection, My Book Duo is the great storage solution offering the capacity and security you need.
  • Dual-drive performance with fast data transfers
    Transfer a Full HD movie in seconds. Get the speed you need to transfer your entire media collection with ease.
  • Massive capacity to hold all your large media files
    My Book Duo is your storage vault. With great capacity, you can organize and save your entire photo, video and music collection, and other important documents in one safe place.
  • Complete backup solutions to secure your data from loss
    My Book Duo provides multiple backup possibilities to help protect your media collection and important files with local, cloud and system-level backup.
  • Fast and reliable hardware encryption with password protection
    My Book Duo provides password protection to ensure your entire media collection and important files are protected from unauthorized access.
  • Expand capacity and organize your workspace
    My Book Duo features two additional USB expansion ports allowing you to connect additional devices, such as another external drive to increase your storage, or simultaneously charge your smartphones, tablets or other USB devices.
  • Easy to set up, easy to use
    My Book Duo is pre-formatted NTFS and is ready to use right out of the box.
  • User serviceable enclosure
    Ready to upgrade your drives to expand storage capacity? With the simple push of a button, pop open the enclosure and insert new drives with ease. No tools required.
WD My Book Duo WDBFBE0160JBK - hard drive array
Hard drive array
Total Array Capacity
16 TB
USB 3.1
2 (installed) / 2 (max)
EMEA
Built-in Devices
USB 3.0 hub
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 8 TB HDD
Apple macOS 11 or later, Windows 10 or later
AC 120/230 V - 47/63 Hz
10 cm x 16 cm x 18 cm
2.36 kg
Hard drive array
Enclosure Colour
EMEA
Chassis
Built-in Devices
USB 3.0 hub
2
Supported Devices / Modules Qty
2
Storage
16 TB
HDD Array External Interface
USB 3.1
Storage Controller
RAID
Data Transfer Rate
290 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 8 TB
Expansion Bays
2 (total) / 0 (free) x internal
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.1 - 24 pin USB-C
Hardware encryption, password security
1 x USB-C cable , 1 x USB-C to USB-A cable
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
RoHS, AES-256
External power adapter
10 cm
16 cm
18 cm
2.36 kg
5 °C
35 °C
Form Factor: 3.5
Capacity: 16TB
Interface: USB 3.1
Brand: Generic
