WD 4TB Elements 2.5" USB 3.0 Portable Hard Drive
Quicklinx: DD9KWS00 Mfr#: WDBU6Y0040BBK-WESN
Form Factor: 2.5
Capacity: 4TB
Interface: USB 3.0
£127.07 ex VAT
£152.48 inc VAT
WD Elements portable storage with USB 3.0 delivers perfect data transfer rates, universal connectivity and great capacity for value-conscious consumers who are looking for reliable, high-capacity storage to go.
  • Perfect transfer rates
    When connected to a USB 3.0 port, WD Elements portable storage delivers perfect performance for data transfers. Transfer a full-length HD movie in a fraction of the time it takes with USB 2.0.
  • USB 3.0 and USB 2.0 compatibility
    Works seamlessly with the USB 3.0 devices and is backward compatible with USB 2.0 devices as well.
  • High capacity in a small enclosure
    The small, lightweight design offers high-capacity storage, making WD Elements portable storage the ideal companion for value-conscious consumers who want to take their important files with them.
  • Improve PC performance
    When your internal hard drive is almost full your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements and get your PC moving again.
  • WD quality inside and out
    Your data is very important to you. So this drive is built inside to the demanding requirements for durability, shock tolerance and long-term reliability. It is also protected with a durable enclosure designed for your great style.
WD Elements Portable WDBU6Y0040BBK - hard drive - 4 TB - USB 3.0
Hard drive - external (portable)
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
NTFS formatted
Power Source
USB bus
Worldwide
4 TB
USB 3.0
NTFS formatted
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows
1 x USB cable
RoHS
Worldwide
5 °C
35 °C
Form Factor: 2.5
Capacity: 4TB
Interface: USB 3.0
Brand: WD
