Product
WD My Passport 2TB Orange Portable USB 3.0 Hard Drive
Quicklinx: DL03WS00 Mfr#: WDBS4B0020BOR-WESN
Form Factor: 3.5"
Capacity: 2TB
Interface: USB 3.0
Colours:
£52.79 ex VAT
£63.34 inc VAT
The My Passport portable drive is trusted to store the massive amounts of photos, videos and music you love. It fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
  • Auto backup
    Automatically back up photos, videos, music and documents from your system onto your My Passport drive. Set it to your schedule. Just pick the time and frequency.
  • Password protection
    Built-in hardware encryption helps keep your content private and safe. Easily add a return-if-found message as the password prompt in case your My Passport drive ever gets lost. Even great minds like yours can accidentally leave things behind.
  • Easy to use
    Ready to use out of the box, you can start transferring files, saving memories and backing up right away.
WD My Passport WDBS4B0020BOR - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, automatic backup
Power Source
USB bus
Enclosure Colour
Orange
110 mm x 81.5 mm x 13.8 mm
170 g
Worldwide (excluding China)
3 years warranty
2 TB
Hardware Encryption
256-bit AES
USB 3.0
110 mm
81.5 mm
13.8 mm
170 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup, WD Discovery
Microsoft Windows 7 / 8.1 / 10
1 x USB 3.0 cable - external
Directive 2002/95/EC
Enclosure Colour
Orange
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
20 - 80%
Form Factor: 3.5"
Capacity: 2TB
Interface: USB 3.0
Brand: WD
Price Range Ex VAT: 50 - 100
