USB 3.0 connectivity delivers maximum performance for transferring files to and from this drive.
With 750 GB capacity in a lightweight design, this drive is the ideal companion for users on the go.
When your internal hard drive is almost full your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements portable storage and get your laptop moving again.
Maximum transfer rates
USB 3.0 connectivity delivers maximum performance for transferring files to and from this drive. -
High-capacity in a sleek design
With 750 GB capacity in a lightweight design, this drive is the ideal companion for users on the go. -
Improve PC performance
- WD Elements Portable WDBUZG7500ABK - hard drive - 750 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 750 GB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- NTFS formatted, cloud backup
- Power Source
- USB bus
- 82 mm x 111 mm x 15 mm
- 134 g
- Localisation
- Middle East, Africa, Europe
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Capacity
- 750 GB
- Interface
- USB 3.0
- 82 mm
- 111 mm
- 15 mm
- 134 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- WD SmartWare Pro (30 days trial)
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- Cables Included
- 1 x USB cable
- Plug and Play, RoHS
- Localisation
- Limited warranty - 2 years
- 5 °C
- 35 °C
