WD 5TB Elements USB 3.0 3.5" Desktop Hard Drive
Quicklinx: 9QSQWS00 Mfr#: WDBWLG0050HBK-EESN
When connected to a SuperSpeed USB 3.0 port, WD Elements lets you access and save files faster than ever. Transfer a 2-hour HD movie in just 3 minutes instead of 13 minutes.
Formatted to work right out of the box with your Windows PC. Just connect the power and plug the drive into the USB port on your computer to instantly add more storage.
With 5 TB capacity, there's plenty of room for all your important files and precious memories.
  • Transfer files faster than ever
  • Plug-and-Play simplicity
  • Massive capacity
  • Improve PC performance
    When your internal hard drive is almost full, your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements desktop storage and get your computer moving again.
  • Universal connectivity
    With this single drive you can connect to the USB 3.0 devices or to your USB 2.0 devices as well.
WD Elements Desktop WDBWLG0050HBK - hard drive - 5 TB - USB 3.0
Hard drive - external (desktop)
5 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Power Source
Included AC adapter
48 mm x 135 mm x 165.8 mm
950 g
United Kingdom
Microsoft Certification
Compatible with Windows 7
5 TB
USB 3.0
NTFS formatted
48 mm
135 mm
165.8 mm
950 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD SmartWare Pro (30 days trial)
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable - external
Plug and Play, RoHS
United Kingdom
5 °C
35 °C
