Product
WD 3TB My Passport for Mac 2.5" USB 3.0 Portable Hard Drive
Quicklinx: CFGVWS00 Mfr#: WDBP6A0030BBK-WESN
Select:
My Passport for Mac
My Passport for Mac is the sleek, portable hard drive designed for photographers, graphics professionals and road-warriors who want to take their digital life with them. It's compatible with Apple Time Machine and is an ideal companion for your MacBook or MacBook Air. Password protection and hardware encryption let you secure your files from unauthorized access.
Built for Mac, Time Machine-Ready
Ready to go with your Mac straight out of the box, the My Passport for Mac drive helps protect your files with Apple Time Machine backup software. And you can quickly drag and drop files to and from the drive with Finder.
Password Protection with Hardware Encryption
Built-in 256-bit AES hardware encryption with WD Security software helps keep your content private and safe. Add a 'return-if-found' message as the password prompt in case your My Passport for Mac drive ever gets lost.
Easy to Use
Ready to use out of the box with your Mac, you can start transferring files, saving memories and backing up. The My Passport for Mac drive works with Apple Time Machine, and included WD Security software helps protect your data.
Reimagined Design
Designed to complement your Mac, the rich, black shine and artful composition makes the My Passport for Mac drive fashionably fun.
Massive Capacity
With up to 4TB, you can take the massive amounts of photos, music and videos you love wherever you go, and have plenty of room for other important documents, too.
WD Quality Inside and Out
WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability. And we stand behind the trusted My Passport for Mac drive with a 2-year limited warranty.
  • Secure and reliable
    Trust My Passport for Mac to help protect your precious memories and confidential files.
  • Compatible with Apple Time Machine
    Compatibility with Apple Time Machine makes it easy to regularly back up the files that define your creative life. Set up a backup schedule and rest assured that your files are protected.
  • Sleek design with high capacity
    With extreme capacities in the palm of your hand, My Passport for Mac is an ideal companion for your MacBook. Its stylish, compact design complements your on-the-go lifestyle.
  • Ultra-fast transfer rates
    The power of USB 3.0 lets you access and save files in blazing-fast speed. Best of all, because it's powered by the USB port, no separate power supply is needed.
  • You're in control
    Configure, manage and diagnose your drive with WD Drive Utilities. Run drive diagnostics, erase and format your drive, register your drive and more.
WD My Passport for Mac WDBP6A0030BBK - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, automatic backup, Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus
Enclosure Colour
110 mm x 81.5 mm x 21.5 mm
250 g
Worldwide (excluding China)
3 years warranty
3 TB
Hardware Encryption
256-bit AES
USB 3.0
110 mm
81.5 mm
21.5 mm
250 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD Backup
Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan
1 x USB 3.0 cable
RoHS
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
65 °C
