WD 3TB My Book USB 3.0 Desktop Hard Drive For Mac
Quicklinx: 913RWS00 Mfr#: WDBYCC0030HBK-EESN
My Book® for Mac® desktop storage features ultra-fast USB 3.0 connectivity, is formatted for Mac, compatible with Apple® Time Machine®, and offers password protection with hardware encryption.
Ultra-fast transfer rates - My Book for Mac desktop storage features SuperSpeed USB 3.0 for ultra-fast data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to access and save files in record time.
Universal connectivity - With this drive you get connectivity with the latest USB 3.0 devices as well as backward compatibility with USB 2.0 devices.
High capacity in a sleek design- With up to 3 TB capacity, there's plenty of room to store and protect your creative endeavors and your photos, videos and music.
Fast, seamless Time Machine backup - Back up your files quickly and easily with Apple Time Machine.
HFS+ Journaled - Works right out of the box with Max OS X 10.5 or later operating systems. Can be reformatted for Windows operating systems.
WD Security™ - WD Security software allows you to set password protection and hardware encryption for your drive to protect your files from unauthorized use or access.
WD Drive Utilities™ - Register your drive, set drive timer, run diagnostics and more using WD Drive Utilities.
WD quality inside and out - We know your data is important to you. So we build the drive inside to our demanding requirements for durability, shock tolerance and long-term reliability. Then, we protect the drive with a durable enclosure designed for beauty.
  • Ultra-fast USB 3.0 connectivity
  • Compatible with Apple Time Machine
  • Password protection with hardware encryption
Ideal For
  • Transferring files in blazing fast USB 3.0 speed
  • Backing up your files with Apple Time Machine
  • Securing private or sensitive data with password protection and hardware encryption
  • Adding extra storage space for photos, videos and music
Kit Contents
  • Desktop hard drive
  • USB cable
  • AC adapter
  • Quick Install Guide
Notes
  • Formatted HFS + Journaled for Mac OS X, Snow Leopard™, Lion™ or Mountain Lion™
  • Requires reformatting for Windows® operating systems Note: Compatibility may vary depending on user's hardware configuration and operating system
  • 3-year limited warranty worldwide
  • Smaller, sleeker, more streamlined design
    They've made these award-winning drives even smaller, sleeker, and more elegant. As always, this book-like shape takes up minimal space on your desk and allows two or more My Book drives to nestle neatly together like volumes on a shelf.
  • Designed for Mac
    Formatted for Mac and compatible with Apple Time Machine, this drive is plug-and-play ready for Mac computer users.
  • Drive lock
    Gain peace of mind knowing that your data is protected from unauthorized access or theft with password protection and 256-bit hardware-based encryption.
  • Illuminated capacity gauge
    See at a glance how much space is available on your drive.
  • USB 2.0 interface
    The simple connection offers convenience and compatibility among multiple computers.
  • Power miser
    My Book external drives are designed to save energy. WD GreenPower Technology lowers internal drive power consumption by up to 30%, a sleep mode reduces power during idle times, and a power-saving feature turns the drive on and off with your computer.
WD My Book for Mac WDBYCC0030HBK - hard drive - 3 TB - USB 3.0
Hard drive - external (desktop)
3 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, Apple Time Machine compatible, HFS+ formatted
Power Source
Included AC adapter
Enclosure Colour
50 mm x 140 mm x 170 mm
1.01 kg
Middle East, Africa, Europe
3-year warranty
3 TB
USB 3.0
50 mm
140 mm
170 mm
1.01 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD Drive Utilities
Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable
RoHS
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
