WD Elements SE portable storage offers high capacity to go, fast data transfer rates and universal connectivity with USB 2.0 and USB 3.0 devices. The small, lightweight drive features large storage with high quality and reliability.
USB 3.0 and USB 2.0 compatibility
Get compatibility with USB 3.0 computers and backward compatibility with USB 2.0 computers in this single drive. -
Improve PC performance
When your internal hard drive is almost full, your PC may slow down. Don't delete files. Instead, free up space on your internal hard drive by transferring files to the WD Elements SE portable storage to get your laptop moving again. -
WD quality inside and out
WD Elements SE portable storage with enclosure is built to meet demanding requirements for durability, shock tolerance and long-term reliability to help protect the data, that's important to you.
- WD Elements SE WDBJRT0030BBK - hard drive - 3 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 3 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- NTFS formatted
- Power Source
- USB bus
- 81.57 mm x 110.07 mm x 20.96 mm
- 230 g
- Localisation
- Worldwide (excluding China)
- 2-year warranty
- Capacity
- 3 TB
- Interface
- USB 3.0
- NTFS formatted
- 81.57 mm
- 110.07 mm
- 20.96 mm
- 230 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- WD Drive Utilities, WD Discovery
- OS Required
- Windows 10 or later
- Cables Included
- 1 x USB 3.0 cable
- Localisation
- Limited warranty - 2 years
- 5 °C
- 35 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 65 °C
