WD 2TB My Passport Ultra USB 3.0 2.5" Hard Drive Black
Quicklinx: 8QH6WS00 Mfr#: WDBMWV0020BBK-EESN
My Passport Ultra delivers USB 3.0 performance and high capacity in a sleek design. It features WD SmartWare Pro automatic backup software for back up to the drive itself or to your Dropbox account. Secure your files with password protection and hardware encryption. It's the ideal companion for anyone who needs to take their digital content on the road.
  • Sleek design with high capacity
    This drive is sleek and fast with plenty of capacity for your important digital content.
  • Local and cloud backup
    WD SmartWare Pro automatic backup software lets you choose when and where you back up your files.
  • Ultra-fast transfer rates
    When connected to a USB 3.0 port, My Passport Ultra lets you access and save files with blazing speed. Reduce transfer time by up to 3 times when compared to USB 2.0 transfer rates.
  • USB 3.0 and USB 2.0 compatibility
    With this single drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
  • Secure your files
    WD Security allows you to set password protection and hardware encryption for your drive to help protect your files from unauthorized use or access.
  • USB-powered
    Powered directly from the USB port on your PC. No separate power supply is needed.
WD My Passport Ultra WDBMWV0020BBK - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Hardware encryption
Power Source
USB bus
Enclosure Colour
82 mm x 20.9 mm x 110.5 mm
230 g
Middle East, Africa, Europe
3-year warranty
2 TB
Hardware Encryption
USB 3.0
Hardware encryption
82 mm
20.9 mm
110.5 mm
230 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
WD Security, WD Drive Utilities, WD SmartWare Pro
Apple MacOS, Microsoft Windows Vista / XP / 7 / 8
1 x USB cable
RoHS
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
