WASP WWS850 Bluetooth Wireless Scan USB
Quicklinx: 88T7WS00 Mfr#: 633808503109
Wasp Barcode Technologies WWS850 Bluetooth Wireless Barcode Scanner Kit gives you the freedom to roam. With the WWS850 Barcode Scanner, you can take your scanner to your inventory instead of your inventory to your scanner. The WWS850 Barcode Scanner uses Bluetooth technology, which allows you to scan barcodes and transmit the data up to 160 feet depending on the environment. Scan barcodes from 1 to 25 inches with the aggressive Laser scan engine. The kit comes complete with Bluetooth wireless barcode scanner, Bluetooth radio/recharge base, and cable for the base. Ideal for warehouse, factory floor, field service and retail environments.
Wasp WWS850 Wireless Laser Barcode Scanner Kit - USB - barcode scanner
Barcode scanner - portable - Bluetooth
United Kingdom
Wireless
Wireless Connectivity
Bluetooth
Microsoft DOS, Apple MacOS, Microsoft Windows 98 Second Edition, Microsoft Windows 95/98/ME/NT/2000/XP
United Kingdom
Barcode
Interface Type
Bluetooth
Max Working Distance
63.5 cm
Decode Capability
Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, UCC/EAN-128, NW-7, Telepen, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Italy Pharmacode, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey, GS1 DataBar-14
Wireless
Reduced Space Symbology (RSS)
Bluetooth
1 x USB - Type A
Cradle
1 x USB cable - external
