WASP WWS650 2D Wireless Barcode Scanner (incl base)
Quicklinx: GB7GWS00 Mfr#: 633809002885
The Wasp WWS650 2D wireless barcode scanner is as affordable as it is reliable. This multitasking, wireless barcode scanner is capable of reading codes on mobile phones and other reflective devices. It is ideally suited for retail (POS, inventory, good receiving, etc.) and general commercial applications such as: access control for transportation and entertainment, banking, postal, and utility services.
Wasp WWS650 - barcode scanner
Barcode scanner - portable - Bluetooth 3.0
Minimum Bar Width
4 mil
Scan Field Width
0.5 cm - 35 cm
Wireless
Wireless Connectivity
Bluetooth 3.0
16.3 cm x 9.1 cm x 4.1 cm
200 g
Barcode
Interface Type
Bluetooth 3.0
Minimum Bar Width
4 mil
Scan Field Width
0.5 cm - 35 cm
Light Source Wave Length
610-650 nm
Max Working Distance
35 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, GS1 DataBar, QR code, MaxiCode, Aztec code, Postnet, PDF417, Data Matrix, PLANET, Australian Post, British Post, Canadian Post, China Post, Japanese Post, Kix (Netherlands) Post, Korea Post, MacroPDF417, Royal Mail, Micro QR code, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Composites, China Han Xin Code, UPC A Composite, UPC E Composite, Aztec Mesa
Wireless
OK Notification
Beeper, LED indicator
ESD (electrostatic discharge) safe
Bluetooth 3.0
1 x USB
FCC Part 15, RoHS, WEEE, IP42
16.3 cm
9.1 cm
4.1 cm
200 g
50 °C
5 - 95% (non-condensing)
Drop Specification
1.5 m to concrete
