The Wasp WPS200 Omni-Directional barcode scanner is a high performance scanner ideal for retail point-of-sale (POS) and warehouse applications. Utilizing a digital imaging scan engine, the WPS200 is capable of reading both 1D and 2D barcodes with ease. Unique Illumination technology optimizes light levels and provides the ability to read barcodes from mobile phones, tablets, and computer displays.
For busy retail environments, the WPS200 can be used in hands-free and handheld mode. Checkout personnel simply wave the barcode label or tag across the face of the scanner. Regardless of barcode label orientation, the WPS200 Omni-Directional scan engine will quickly read the barcode and assist in the rapid check out of your customers.
The WPS200 Omni-Directional barcode scanner can also be used to scan invoices or pick lists and is a perfect addition to any warehouse. Its rugged housing can withstand repeated 4 foot drops to concrete, and is sealed against moisture and dust (IP52 particulate and water sealing rating). For noisy environments, the WPS200 provides visual feedback, perfect for confirming a positive scan or for precise targeting of a single barcode from a group of barcodes.
- Wasp WPS200 Omni-Directional - barcode scanner
- Barcode scanner - desktop - stationary - USB - decoded
- Minimum Bar Width
- 5 mil
- Scan Field Width
- 17.8 cm
- Scan Element Type
- Visible laser diode
- Scan Speed
- 1768 scan / sec
- Connectivity Technology
- Wired
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
- 8.86 cm x 7.52 cm x 14 cm
- 385.6 g
- 2-year warranty
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 5 mil
- Scan Field Width
- 17.8 cm
- Scan Element Type
- Light Source Wave Length
- 650 nm
- Scan Mode
- Fixed projection
- Scan Speed
- 1768 scan / sec
- Max Working Distance
- 21.6 cm
- Decode Capability
- EAN/JAN, Code 93, Code 39, UCC/EAN-128, ISBT 128, QR code, MaxiCode, Aztec code, UPC-A, Discrete 2 of 5, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, PDF417, MSI-Plessey, Data Matrix, Code 39 Trioptic, Hong Kong 2 of 5
- TTL Decoding
- Decoded
- Wired
- Reduced Space Symbology (RSS)
- 1 x USB - Type A
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - external
- FCC Class B certified, CISPR 22 Class B, UL 1950, CSA 22.2 No. 950, EMC, EN 60825, IP52
- Electric Current Required
- 275 mA (operating)
- OS Required
- 8.86 cm
- 7.52 cm
- 14 cm
- 385.6 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Drop Specification
- 1.2 m to concrete
