The Wasp WLR8900 CCD LR (long-range) barcode scanner series is easy to setup and even easier to use. The lightweight, ergonomic design makes it comfortable for daily use. The Wasp WLR8900 barcode scanner series sends data to your active application as if you typed it from your keyboard. It also provides added flexibility over other CCD scanners by being able to scan barcodes from distances of up to 12 inches away.
For fast connection, the WLR8900 can simply be plugged into a keyboard wedge via USB or PS/2. It is designed for retail, point of sale, or any repetitive application where time and accuracy are important factors in making your business succeed.
- Wasp WLR 8905 CCD LR Scanner - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Localisation
- United Kingdom
- Scan Element Type
- CCD
- Scan Speed
- 150 scan / sec
- Connectivity Technology
- Wired
- System Requirements
- Microsoft DOS, Apple MacOS, Microsoft Windows NT, Microsoft Windows 95/98/ME/2000/XP
- 1-year warranty
- Localisation
- United Kingdom
Barcode
- Interface Type
- USB
- Scan Element Type
- CCD
- Scan Speed
- 150 scan / sec
- Max Working Distance
- 30.5 cm
- Decode Capability
- Code 93, Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey
- TTL Decoding
- Decoded
- Wired
- 1 x USB
- OS Required
- Limited warranty - 1 year
WASP WLR8950 Bi-Colour CCD Barcode Scanner
