Get in control of your stock with Wasp Inventory Control - the complete stock management solution for small business. Increase the value of your business, satisfy your customers and create more freedom in your life with Inventory Control.
Engineered to improve efficiency and profitability, Wasp Inventory Control provides the capabilities you need to accurately track stock, without the complexity or expense of an enterprise solution. Easy, efficient, affordable!
Inventory Control allows you to define multiple sites (a warehouse, truck fleet, stock room, or even an installation truck such as a TV or satellite installer) with multiple locations (a bin, shelf, or even a pallet within the location). It's simple to track your stock by location, serial number, lot or any combination of the numerous 'track bys'.
Easily create barcode labels with Wasp Inventory Control. Print barcode labels or stock tags using data from the Inventory Control database. Attach barcoded labels to stock items, physical locations or pallets to quickly improve efficiency.
- Inventory Control RF Enterprise - box pack - 5 mobile devices, unlimited PC users - with HC1
- Product Type
- Box pack
- Category
- Business applications - inventory systems
- Bundled with
- HC1
- Licence Qty
- Platform
- Windows, Pocket PC
- Distribution Media
- DVD-ROM
- Technical support
- Category
- Product Type
- Box pack
- Bundled with
- HC1
- Platform
- DVD-ROM
- Min Supported Colour Depth
- 8-bit (256 colours)
Licencing
- Licence Qty
- Supported OS
- Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows XP Professional SP3, Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows Mobile for Pocket PC 2003 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Embedded Handheld 6.5, Windows 8 (32/64 bits)
- Hardware Requirements
- Microsoft Windows Vista / XP / 7 / 8 - 750 MHz - RAM 1 GB - HD 10 GB , Microsoft Windows Server 2003 - 750 MHz - RAM 1 GB - HD 10 GB , Microsoft Windows Server 2008 - 750 MHz - RAM 1 GB - HD 10 GB , Microsoft Windows Mobile for Pocket PC 2003 or later - RAM 64 MB , Microsoft Windows CE 4.2 or later - RAM 64 MB , Microsoft Windows Embedded Handheld 6.5 - RAM 64 MB
- Additional Requirements
- DVD-ROM, XGA monitor
- Technical support
