The EFF 1140 is a universal support and can be placed easily anywhere you want. It offers an optimal viewing position by the turn function. The cables can be cleverly concealed with the unique Vogel's Cable Inlay System. The A/V support can be adjusted in height and dept to fit different sized equipment.
- Vogel's Evolution EFF 1140 stand - for flat panel / DVD / audio - silver, aluminium
- Product Type
- Stand - floor-standing
- 70 cm x 34.6 cm x 111.3 cm
- 11.9 kg
- Recommended Use
- Flat panel / DVD / audio
- Recommended Display Size
- 25"-42"
- Max Load Weight
- 45 kg
- Silver, aluminium
- 70 cm
- 34.6 cm
- 111.3 cm
- 11.9 kg
- Silver, aluminium
AV Furniture
- Stand
- Recommended Use
- Placing / Mounting
- Floor-standing
- Shelf Qty
- 1
- 25"-42"
- Max Load Weight
- 45 kg
- Rotating, height adjustable shelves, Cable Inlay System (CIS)
