Peerless-AV SmartMount Universal Flat Wall Mount for 32" to 50" Displays
Quicklinx: 7MTXWS00 Mfr#: FRZV
Type: Mounting kit
30 In Stock
£41.65 ex VAT
£49.98 inc VAT
Ideally suited for medium/large LCD screens, the SmartMount SF640P flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 30mm away from the wall.
  • Effortless installation
    The Peerless SmartMount Universal Flat Wall Mount is designed for easy setup with a straightforward bracket and wall plate system, ensuring a hassle-free installation process.
  • Robust support
    Capable of supporting LCD displays up to 68 kg, this mounting kit is built for strength and reliability, accommodating a wide range of screen sizes securely.
  • Versatile compatibility
    Featuring a flat panel mount interface of 400 x 400 mm, the SF640P model offers compatibility with various LCD display models, making it a flexible solution for your mounting needs.
Peerless SmartMount Universal Flat Wall Mount SF640P mounting kit - for LCD display - black
Mounting kit
Mounting Components
Wall plate, bracket
48.3 cm x 3 cm x 34.8 cm
2.2 kg
Recommended Use
LCD display
Recommended Display Size
32"-50"
VESA Mounting Interface
400 x 400 mm
Max Load Weight
68 kg
5-year warranty
48.3 cm
3 cm
34.8 cm
2.2 kg
AV Furniture
Mounting kit
Mounting Components
Wall plate, bracket
Recommended Use
LCD display
400 x 400 mm
32"-50"
Max Load Weight
68 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
