The ViewSonic networkable LightStream PJD6350 features 2x HDMI, 3,200 lumens, high resolution 4:3 (XGA 1024x768), majestic style and thoughtfully intuitive design. It also features a throw ratio of 1.51-1.97 which is ideal for replacing 3LCD projectors like EPSON, NEC, Hitachi, Panasonic, Sony etc.
Exclusive SuperColor 6-Segment Color Wheel maximises colour saturation and brightness for true-to-life image projection in any light, while exclusive SonicExpert speaker design powering a 10W speaker to deliver incredibly clear and audible sound.
A neatly enclosed HDMI-MHL (Media High-Definition Link) compartment supports wireless media streaming from HDMI dongles or MHL connectors (like ViewSonic's WPG-300 and Google Chromecast), while a cable management hood connects onto the back of the projector to eliminate unsightly cable clutter.
With horizontal and vertical keystone correction, corner adjustment, 1.3x optical zoom, and easy network management, the PJD6350 provides flexible setup.
EPSON, NEC, Hitachi (3LCD projectors) distance match
With a throw ratio ranging from 1.51 to 1.97, this projector is primed to replace typical 3LCD projectors (EPSON, NEC, Hitachi, Panasonic, Sony) without having to move or re-install existing ceiling mounts. Also equipped with a 1.3x optical zoom lens, this projector provides mounting flexibility with a wider throw distance range. -
2x HDMI with 3D support
Equipped with two HDMI ports, this projector is perfect for connecting to any HDMI-enabled device such as laptops, tablets, games consoles and DVD or Blu-ray players. It also supports 3D images directly from 3D sources. -
Beautiful design with rear cable cover
With its matte hairline finish, curved edges and tactile keypad this LightStream Projector stands out from the competition. A cable cover completes the look by hiding cable clutter and exposed ports at the rear. -
SuperColor best in class color accuracy
ViewSonic's proprietary Super Color technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-segment color wheel maximizes brightness Increased by 15% or more with the highest color saturation over others in the same class. -
SonicExpert technology for best-in-class sound
ViewSonic's exclusive SonicExpert technology incorporates a ported speaker chamber and a more powerful amplifier to deliver higher volume and the absolute best-in-class sound. -
Easy image adjustments
Horizontal and vertical keystone correction and a corner adjustment feature eliminate crooked and distorted images for a perfectly proportioned picture every time. -
Network control of up to 256 projectors
All LightStream PJD6 projectors come equipped with Crestron RoomView Express, an easy-to-use network management system that lets administrators remotely monitor and control up to 256 LightStream projectors from a single PC. -
Easy remote and app use
A programmable "MyButton" can be configured to launch the most commonly used functions. A single remote control can also control up to eight projectors in the same venue. A Free App (called 'vRemote') also allows users to control a projector via a mobile device.
- ViewSonic PJD6350 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Speakers
- Speaker(s) - integrated
- Power
- AC 100 - 240 V (50 - 60 Hz)
- 315 Watt
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 22000:1 (dynamic)
- Throw Ratio
- 1.51 - 1.97:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Korean, Indic (Indian Languages)
- DynamicEco Mode, sleep timer, Movie Mode
Lens
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Video Interfaces
- VGA, HDMI, component video, S-Video, MHL
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
- Included Accessories
- Cable cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Password protection, security bar, keypad lock
- Power Source
- AC
- Voltage Required
- 315 Watt
- Power Consumption Stand by
- 0.5 Watt
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 27 dB
